Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Detecting light for airflow on bravo xl maytag washer
2 Suggested Answers
  • 24 Answers
SOURCE: Have a Maytag Bravos XL MEDB9504WO that works, but
Sounds like you need new drum rollers, so you need to disassemble the front of the machine and remove drum replace all drum rollers and idler pulley also check blower for damage.
Posted on Aug 01, 2013
I can not open the door on my Maytag top loading washer
Many new washer use a lid lock instead of a brake to keep people from reaching into the spinner before it stops. You probably have a
bad lid lock. Have a repair man open the top cover and repair or replace the lid lock.
Jul 06, 2016 | Maytag Washing Machines
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravos top loading washer; LD error and all lights blinking. It seems to be draining now after I turned off and tried rinse only
Why is my Maytag Bravo washer Model #MTW6600TBO ...
www.shopyourway.com > Manage My Life > Questions
May 12, 2010 - LD error please check for the following: Check for kinked or clogged Drain Hose: ... Bravos® Top Load Washer w/ PowerWash® System.
Aug 08, 2015 | Maytag Washing Machines
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
Jun 19, 2015 | Maytag Washing Machines
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Maytag Bravos XL MCT will not start, light is stuck on "detecting" under airflow. All vents and lint trap are clear.
If the vent output is clear and lint trap is clear, then there are a couple of more hidden spots that air can get backed up.
First off, unplug the dryer before doing any of this. There's a lot of current to that plug, and getting killed is a really bad way to detect a bad wire or to identify where the heater coil inlet is.
  1. Inlet to the heater area. Laundry rooms have lint in them. All the air that gets blown out the back has to come from somewhere. make sure you don't have a clump o dust bunnies on another section of the rear panel.
  2. The blower motor itself. The lint filter can't get everything. The first time I took the back off my old Kenmore and opened up that area after the lint trap, it was like looking at a chalkboard eraser. Solid lint. The fins in the blower were packed tight with more lint. Cleaned it all out, and it ran better than it had in years.
  3. If the wall/floor connector for the vent hose goes anywhere but straight through the wall to outside, look down the hose and clear what you can, then go outside to the outlet and make sure it's not blocked, jammed, frozen shut, or what have you. Clean what you can from that end too.
    Hope this helps!
Good Luck!
Sep 10, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
91 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
