Question about AEG Refrigerators
Aeg s85628sk1 freezer gets too cold. set to -18 but drifts to -24 after several days and the down to -18 again. should temp drift around like this? Water dispenser always frozen up. Have to defrost to get to work but soon freezes up again when switched back on.
  • 298 Answers
SOURCE: Frigidaire FRS26LF8CS3 Side by Side, Freezer ice/cream melting, lower bin food side freezing
(There is a defrost heater on the evaporator in that area.If
you have a VOM you could check it with the power plug pulled out of the wall socket)
if you access the area turn the defrost timer on (clockwise)it should get warm in that area and you shoud hear a popping sound
If you want to tackle the job for yourself all the manuals are here
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FRS26LF8CS3&User=&Search=Search
Posted on Nov 27, 2007
peyton32034
  • 410 Answers
SOURCE: GE TFX27PF refrigerator and freezer still not getting cold enough
the partial frost pattern is an indication of low refrigerant, restriction or bad compressor. if the unit is under 5 years old this repair will probably be under warranty thru GE. if out of warranty then you are looking in most cases between 200-500 dollars for repair. good luck Thanx peyton
Posted on Jan 30, 2009
tborn6
  • 700 Answers
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Posted on Apr 04, 2009
  • 56 Answers
SOURCE: GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
Posted on May 30, 2009
heatman101
  • 43501 Answers
SOURCE: fridge freezer not keeping temp
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 27, 2010
Freezer wont go below -9 degrees
This information does not mean anything to us if you didn't specify the model. In what temperature range a freezer works we knew thanks to the stars.
One star (-6 degrees centigrade) is perfect for making ice cubes and is sufficiently cold to keep food for three or four days.
** Two stars (-12 degrees centigrade) stores food for fifteen to twenty days.
*** Three stars (-18 degrees centigrade) will keep food safe for up to three months.
**** Four stars (below 18 degrees centigrade) means that the compartment provides the ideal conditions for freezing down fresh and pre-cooked foods.
Dado
Oct 27, 2013 | AEG Freezers
How should I set the temperature. The refridgerator and freezer is not able to maintain a consistent temperature. What is the correct freezer and top refridgerator setting and how do I know it has accepted...
Basically the thermostat controlls the freezer temperature which turns the compressor on and off.
The refrigerator section receives cold air from the freezer to cool it down.
So when the freezer is off there may not be enough cold air left for the refrigerator.
Fridges can never give you a perfect temperature every time there will always be a drift one way or another.
Once you reset the temperature the numbers or an led should blink at you to confirm the changes you made
Mar 25, 2011 | Liebherr KGK 2833 Comfort Bottom Freezer...
Fridge freezer not keeping temp
heatman101
Apr 11, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
Last two weeks refrigerator temp goes anywhere from 30-35 degrees and freezer temp -5 to -1 degrees.several times a day we attempt to set temp to reccommended temp, but no success.we do not have mannual,...
fridge temp should be 30 to 35 degrees/freezer -1 to -5 f or between 2 to 5 C for fridge and -18 to -22 C for freezer several times a day is too often...... try once every 2 days without opening door in between checks....
Feb 11, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freezer wont keep icecream .the freshfood compartment is ok. even froze eggs in the bottom shelf
Good day,
Usually a cold weather issue.
If the machine is getting light service, then that can add somewhat to the problem.
The issue here is how much the machine runs per day,or more important, how much time it's off.
When it runs less because of cool dry conditions, the freezer will run less. Ice cream needs colder temps than other items.
One step that can help, is placing it on the lowest part of the freezer.
As far a food freezing only on the bottom of the fresh food section,
The longer off times contribute to that. Cold air, on the off cycle drift from the freezer compartment thru the returns into the bottom of the fridge section, which can cause that problem.
This is all based on the design of the machine, which has one compressor and one fan circulating motor.
Hate to sound corny, but, if you find a house with 7 kids and a stay at home Mom, who cooks all the meals, the door openings are high enough that this problem can't occur.
Feb 06, 2010 | GE Refrigerators
The Temperature settings keep changing
The board is drifting. all this is done in the progra Board Needs to be replaced.
Sep 21, 2009 | GE Profile¿ Arctica® Energy...
Cursor when using Logitech Trackball sometimes drifts up or down
I finally just was able to solve this problem! I saw somewhere that someone had made sure their primary mouse was selected under hardware, which got me thinking. I thought I had seen a second mouse option somewhere. So, I went into my Control Panel > System > Device Manager and click the arrow next to Mice and other pointing devices. Sure enough, there were two listed. A seemingly generic one and my Logitech I've been using. I right clicked on the generic one and chose disable and the drifting IMMEDIATELY stopped. I went so far as to re-enable that generic to see if it was a fluke because it had stopped drifting on its own yesterday, nope as soon as I enabled the generic device, drifting started again. So Happy!!!
Jun 11, 2009 | Logitech Trackman Marble FX Trackball
Refrigerators Logo
Top AEG Refrigerators Experts
ashburton
Ian Jones
Jim Goldsmith
Jim Goldsmith
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
