Question about Beko Refrigerators
Too warm on lowest setting but not cold enough
3 Suggested Answers
SOURCE: I have a KitchenAid side by side refrigerator that
It is likely the defrost not working and ice blocking the path between the two sides. I have the same problem with a jenn-aire. For mine, there are several possibilities. Defrost thermostat or contol board are the most likely. All of them work similarly. Keep looking on this site and you will find others with your model that have had the same problem.
I guess I am lucky because mine was not working on either side yesterday. I thought replacing the relay on the compressor was the only thing I needed to fix...wrong.
I am working on it again today. Hope this will help you.
Posted on Aug 01, 2009
  • 157 Answers
SOURCE: kitchenaid superba refrigerator side at lowest
Check the setting of your vents between sides and open them, sometimes you have to pull out the produce drawer to find the lower one
Posted on Jun 23, 2011
Replace blend door actuator motor
Could be, check the door and see if it works correctly
Aug 17, 2013 | Mitsubishi Cars & Trucks
I have a Frigidaire model# FRS26H7CSB1. THE FREEZER IS NOT GETTING COLD ENOUGH AND THE FRIG IS COLD BUT ONLY WHEN SET TO LOWEST TEMP SETTING. The metal frame/pillar between the freezer and frig is very...
The freezer not getting cold enough is defiantly due to the condenser fan motor not working. You would be best served to replace the fan motor with the correct part number though others will work, a small desk fan blowing in the back would work. As to the temperature issue in the refrigerator, you might have a bad t-stat.
Mar 12, 2013 | Frigidaire Refrigerators
Kitchenaid superba refrigerator side at lowest temp setting is not cold enough. Freezer temp is fine.
Jun 23, 2011 | KitchenAid Superba Architect KSCS25INSS...
Hi my freezer is not cooling enough. Ealier my
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 24, 2011 | Fisher and Paykel Active Smart E522B...
Which will provide the lowest heat? low 10 hours or warm setting. Thanks
The WARM setting is the lowest heat. Here's a quote from the user manual:
"WARM is ONLY for keeping already cooked food at the perfect serving temperature. DO NOT cook on the WARM setting."
This is because at the WARM setting, the temperature doesn't get hot enough to kill food-borne bacteria.
Jan 18, 2011 | Rival 38601 Smart Pot 6-Quart
Refrigerator side too warm
SHOULD HAVE A AIR DIVERT ER CONTROL TO SEND MORE AIR TO FREEZER AND LESS TO FRIG SIDE TRY TO SENT MORE AIR TO FREEZER SIDE AND LEAVE COLD CONTROL COLD ENOUGH TO ACCOMMODATE THE FREEZER SIDE TO BE COLD ENOUGH
Jan 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Kenmore 73503 - Freezer very cold refrigerator warm.
Check and find out if your fan operates in the freezer. Cold air is heavier than hot air and will settle to the lowest point. The refrigerator not cooling tells me it is not getting the air for cooling which comes from the freezer.
Jun 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
My refrigerator does not cool properly. The freezer does not have ice built up and the fan is working, I can here it blowing when i open the freezer. The freezer almost works too well, it is at its lowest...
The lowest setting in the freezer compartment may be set to cold holding back cooling to the refrigerator. Try your settings at mid-point on both refrigerator and freezer settings.
Dec 05, 2007 | Kenmore 73503 Stainless Steel Bottom...
Kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Dec 04, 2007 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
11 people viewed this question
Top Beko Refrigerators Experts
AJMAL KHAN
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
