Question about Yamaha Audio Players & Recorders
How do I hook an EQ to my yamaha m65 amp? - Yamaha Audio Players & Recorders
  • 35 Answers
Your eq should either come between the outputs of your mixer and the inputs of your amp, or you can connect your source (guitar, keyboard, microphone) into the eq and out into either a mixer or straight to the amp
Posted on Feb 20, 2014
4 Suggested Answers
marsrover
  • 682 Answers
SOURCE: Conecting my EQ to my Yamaha reciever
your media out(dvd-cd-dat-deck player)-to equalizer in-and equalizer out to aux or cd in receiver.
Posted on Jul 19, 2008
  • 1114 Answers
SOURCE: How do I connect my Yamaha eq-70 to my Yamaha
from your receiver; R&L PRE OUT to R&L LINE IN of Equalizer.
And - from Equalizer R&L LINE OUT to Receiver MAIN IN.
http://www.yamaha.com/yec/customer/hookupdiagram.html?CTID=5010070.
Hope this helps!
Posted on Aug 10, 2009
gaurav_music
  • 17 Answers
SOURCE: How to hook up my Yamaha EQ-70 Equalizer
This is official image from Yamaha. If need to know more, go to the below address -
http://www2.yamaha.co.jp/manual/pdf/av/english/am/AV-90PY.pdf
download the amp's manual & you will find on page no. 7
Posted on Aug 20, 2009
Im trying to hook up a eq to my yamaha c80 preamp and dont have preamp out puts how do I go about doing it?
Hello Tom. The preamp outputs are on the right hand side of the back panel. You have normal and inverted outputs. These are RCA connections and should be connected to the inputs of an EQ unit. The outputs from the EQ unit are then connected to the input of your amplifier (c65) Perhaps I am misunderstanding youtr question? If I have not answered helpfully, feel free to ask further questions.
Cheers, Don.
Jul 07, 2014 | Yamaha Audio Players & Recorders
Hook up a yamaha htr5840 to a nikko eq-1
generally an equlizer hooks up to the amp auxilary- if the amp has auxilary at the back.then hook up devices to the equalizer.
hook up red and white wires to equalizer output and the other end to amp aux red and white holes at the back of the amp then turn nob on amp to aux.If you dont have aux then try tape function
Dec 07, 2013 | Audio Players & Recorders
I recently bought the yamaha rx-v567 and I own a yamaha EQ-70. How do I configure and hook up the EQ to the receiver?
The EQ is connected via one of the Tape loops on the amp (rec out from EQ to play in on amp,rec out on amp to play in on EQ). You then switch "Tape Monitor" on to hear the sound with the EQ settings applied. You can also connect it across Pre out and Main in should you have such sockets. I'm pretty sure it will only affect the main two front channels and not the surround channels.
Dec 19, 2010 | Yamaha EQ-70 Home Equalizer
I have a Yamaha M65 520w power amp, a HTR 5630 210w EQ and a GE-60 Rcvr all in excellent condition. I'm having difficulty hooking them all up to each other and 2 prs of speakers. I'm have 2 Cerwin Vega CLS...
First of all it is important when you are using such good quality system to have an idea of the room. The accoustic quality of the room is a great factorr as even the best system may sound poor. Hence I owul like you to firrst rearrange your system with the Cerwin in the front and the DCM in the rear. Now the most IMPORTANT POINT you must be careful is to connect your speakers with the corrrect Phasing. The positive and negative must be correct , if not the sound will cancel off. So test this out. Connection of the L&R inputs must be also in order without crossing over from the source to the equaliser to the main amp. Now if you have set the equaliser right check for gain in each frequency. If not try to disconnect the equaliser and connect source to amplifier directly and test. make a assesment for good quality. You can also try to reverse ONE of the rear speakers for any improvement. I hope this advice helps you. Good day
Jun 17, 2010 | Yamaha Audio Players & Recorders
Hi! ALL How do I connect my Yamaha eq-70 to pre amp and power amp my Yamaha thanks
Pre-amp out to input of EQ
Output of EQ to poweramp.
If that doesn't help post all your model numbers and I will look it up.
Cheers,
Jan 06, 2010 | Yamaha EQ-70 Home Equalizer
I have a Yamaha HTR-5890 receiver and I am trying to hook up a Yamaha EQ-32 10 band graphic equalizer to the receiver. The frequency spectrum analyzer on the equalizer is working but the graphic...
must have the tape monitor to work the regular tape loop does not physically go back into the receivers processor.
only other solution is if the receiver has PRE out and ins use the PRE out to the EQ then back into the PRE in.
if you have the OUT but no in then the solution would be to go out of the EQ and into an external amp.
In my experience "young adults" like using EQ's to boast bass output.
If that's your goal a POWERED subwoofer is what you need.(check out polk audio direct on ebay)
Your unit is a 7.1 surround receiver the reason that it doesn't have the capability for an EQ is that it messes up the surround sound processor.
If the sound is not what you are looking for the issue more than likely is with the speakers. post a messege with what you want to achieve and I'll try to point you in the right direction.
Dec 29, 2009 | Yamaha HTR-5890 Receiver
Jul 05, 2009 | Yamaha EQ-70 Home Equalizer
Yamaha rx-797 w/Yamaha ge-60 eq utilizing prein/main out ..and ad
It sounds like you want to use the external amp rather than the internal one. If that is the case, just connect the output of the EQ to the input of the external amp. All you are doing is inserting the EQ between the amp stages now. Using the mx-1 rather than the internal amp is no different.
Dan
Feb 25, 2009 | Yamaha MX-D1 2-Channel Amplifier
Hooking up an EQ on a Yamaha HTR 5860
Are you nuts? You dont need EQ to this system.This is such a nice syetem,inbuilt EQ gives very good output.Don't try to connect EQ if you are not an engineer.It can be connected with external source
Feb 10, 2007 | Yamaha HTR-5860 Receiver
100 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
