Question about Minolta Di152 Laser Printer
Fix paper jam
Paper is caught in right roller, says remove green clips to dislodge, but there are no green clips!
  • Minolta Master
  • 6,696 Answers
Sir there showed be two green release levers on each side of the Fusing unit the part that get very hot. THEY mite have been broken off. Get a new fusing unit? or have tech come out and look at.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 04, 2015
  • 214 Answers
SOURCE: paper jam
open doors and find these solenoids, clean them and make sure they are moving fine, its not so hard. just step by step move with paper and find out where the solenoids are. solenoids aren't expensive so if its a solenoid problem you should fix it
Posted on Jun 19, 2008
  • 29 Answers
SOURCE: Minolta 2350DL laser printer paper jam that will not clear
You have to take off the roller . :)
Jus ask me
  • 120 Answers
SOURCE: I had a jam, now not working!
Hi
Just turn of the printer for five minutes and then turn on...
Thank you
Posted on Dec 29, 2008
DLBurkhart
  • 210 Answers
SOURCE: paper Jams (xylophone effect)
This problem is caused by a poor glue compound used on a solonoid assembly (SL3) in the back of the printer. Although difficult to get to, it is easy to fix.
Remove the back panel. Now remove the power board (PWB-A) - that's the lower-left board with the over-abundance of connections. At the top of the newly exposed area will be a solonoid assembly (SL3) - a small, black, round device connected by two wires and mounted to a brass-colored bracket. This assembly is mounted by one screw. Remove the screw and the solonoid assembly. Now that you have the solenoid assembly out, the repair should be a snap.
Notice on the assembly will be a brass lever held in place by a spring. At the tip of the lever that rests against the brass bracket, you should be able to see a tiny black pad when you push down on the other end of the lever. The glue that holds the black pad in place is the problem. The pad is likely part-way to most of the way out of position. Lining the pad back up with the tips of both brass pieces and supergluing it will do the trick. Just make sure to not superglue the brass pieces together and to let the superglue cure before putting it back together.
As to exactly why this repair procedure works, I'm unsure. I can only speculate that the lever must rest too far from the solonoid and be failing to stop the gear that feeds the paper. Or in my case, with only one or two folds in the paper, it must have been functioning too slowly.
Posted on Sep 11, 2009
firecontrol7
  • 6696 Answers
SOURCE: duplex jamming of copy paper
Clean the rollers and clean the clutches mounted in the duplex cover to the rear of the duplexer Also the fuser mite be bad the fuser inter connects with the duplexer
Posted on Apr 03, 2010
Paper jams in heater
Hello
An overheated fuser is one of the most common causes of a paper jam. When large loads of print jobs are pushed through a printer, the fuser slowly starts to warm up. As the fuser warms up, the heat causes the corners of the printer paper to bend. The hotter the fuser gets, the more the paper bends. Eventually the paper bends so much that it causes the paper to get stuck in the fuser, causing a jam.
If you cannot find any other reason for a continuous printer jam, the problem may be the roller. A cracked roller can easily grab a piece of paper and get it caught. A glazed-over or dirty roller can also cause the paper to get caught on the roller and jam the printer. If the roller is cracked or glazed, you may need to call your print technician or replace the roller.
THANK YOU FOR VISITING FIXYA
Mar 03, 2011 | Ricoh Aficio CL7000DTL Laser Printer
Paper jam in the region of rolling
rollers should be cleaned with a special solution if you do not use alcohol or replaced in case it rolls after cleaning paper jam message appears. If you use long rolls wear and print out if you need inlocuite.Observati paper reception area. that there was a paper route in case you caught it ever caught and torn paper inside the printer .. good luck!
Feb 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I HAVE A HP 4345 THAT HAVE A PAPER JAM ERROR. THERE IS NO PAPER JAM. HOW DO I FIX THE ERROR?
If safety is not caught up paper, paper pick rollers probably replace worn or cleaned rollers
Oct 19, 2010 | HP Office Equipment & Supplies
Error message: No TR Roller Install the transfer roller
Hi
This error has already been noticed by Brother and they have a fix for this issue. This message will appear on your Brother machine if the ground clip is not present on the Transfer Roller Assembly. The clip can become dislodged due to a paper jam or removal of the Transfer Roller assembly.
To check the fix from Brother visit this link--
Brother TR Roller Install error removal Pictures
Please get back to me if you have any queries.
Daniel Scott
Jun 22, 2010 | Brother MFC-9420CN All-In-One Laser...
Paper jammed message won't go away
Presumably this error follows an actual paper jam (whether the culprit has admitted it or not). The following is general advice that applies to paper jams in most printers, copiers, etc.
In my experience at least 98% of paper jam errors are because a piece of paper is still caught inside the printer. The remainder are generally due to a damaged paper jam detector (usually a small plastic arm which actuates a switch inside the printer) or less commonly a failure on the PC board which senses paper jams.
Please return to point 1 and look (again) for a piece of paper jammed in the printer. If the jammed paper was torn from the printer, only a small remnant has to remain inside the printer to generate an unclearable paper jam error.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab. Occasionally a page can wrap completely around a roller and be very hard to see. Be very suspicious of any 'white' roller' - check at the ends to note if the roller is actually a different colour with a complete page wrapped around it (generally then only removable by tearing other than complete disassembly by a professional). If paper was torn you may need a pair of tweezers and some determination to remove any small paper pieces wedged inside the printer. Ensure the printer is unplugged from the wall and avoid damaging any rollers or other parts inside the printer. Always remove jammed paper by pulling it in the direction of normal travel only. On rare occasions very serious paper jams may need expert service to dismantle and reassemble the printer.
After finding and removing all paper pieces, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test.
Mar 05, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Paper jammed between 2 red rollers in the back, can;t dislodge
The red rollers are probably replaceable, and therefore removable. Take a close look, and see if you can tell how they would be removed. It will either snap out, or you'll push it to the side and remove one end at a time. It'll be easier to pull the paper without the roller in the way.
While you have the roller out, you can clean it by wrapping packing tape around it a few times.
Jan 03, 2010 | Kyocera Mita FS-1920 Laser Printer
When we put paper in the printer it goes cricked
Lexmark printer have paper roller problem take printer for once service
Jul 25, 2009 | Lexmark X1270 All-In-One InkJet Printer
At power on I get a 13.20.00 jam inside rear door. Nothing is found in the rear door area. I can't find any flag tied up or a sensor to clean.
This error can be misleading at times. Although it says to check the rear, if you haven't already, remove the toner cartridge and check inside. Also, when you look inside you should see a green lever on the right side. Lift that and check to see if there is paper stuck down there. Another place you can look is in the paper tray area. Remove the paper tray and check to see if there is a piece caught on the way up. Keep in mind when removing a jam make sure you get a whole piece of paper, any missing pieces will cause problems later.
If both areas appear to be clear, think back to if you have a paper jam and got the paper out. Did the paper tear? A small piece could be stuck on a sensor within the printer. If you find paper and everything is good to go, check the pick up rollers to ensure jamming won't happen again. They are located on the paper tray (grey/blue roller) they should like mini tires with grooves, NOT smooth. The other roller is located inside the printer.
Mar 26, 2009 | HP LaserJet 4200 Printer
Paper jam on HP officejet j6450
Diana,
They don't bounce well, i've tried it.
Loon in the rear for an access door.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Canon i255
While I'm not familiar with this unit, the common problem for a paper jam is a foreign object (small piece of paper, staple, paper clip...) caught in the paper feed path somewhere. Slick, worn rollers, a broken gear, or other problem in the drive mechanism will cause such as well. Rarer would be a circuitry problem (motor drive circuit for example).
Sorry I can't be more specific- but a careful look at the paper path is the first possibility.
Dec 17, 2007 | Office Equipment & Supplies
Minolta Di152 Laser Printer Logo
42 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
