Question about Garden
Sears craftman lawn tractor stalls when put in gear after taking deck off
    Problem Solver:
  • 29 Answers
Safety system for deck needs to be energized so tractor remains running
Posted on May 01, 2014
Peuhayd
  • 11 Answers
SOURCE: removing tractor deck to change belt and blades?
if i am thinking of the right model you may be able to get away with first taking off the blade, then to remove the deck should be a number of bolts under the chassis and on top of the deck where it meets the frame... you can get your parts here if your having trouble finding them
 http://www.ordertree.com/modelinfo/MTD/13A1674G401-%281997%29/62.13A1674G401-%281997%29.1.1.1.html
Posted on Sep 06, 2008
wadembly
  • 448 Answers
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Posted on Jun 06, 2009
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
  • 17 Answers
SOURCE: Craftsman 42 '' 19.5hp lawn tractor gear shift
Sounds like your drive belt may have came off or it needs to be replaced. Take the battery out from under the seat to see if belt is still around transaxle. Sometimes it will jump off when doing a lot of starting stopping
Posted on Aug 04, 2010
Testimonial: "Bang-on, Barny. Many thanks."
  • 110 Answers
SOURCE: how to remove gas tank
Hello, removing this tank is easier then it may initially seem. Here are the basic steps:
tilt the seat forward
remove the springs that support the rear of the seat
remove the knob on the transmission shift lever
remove the fuel cap
loosen the bolts under the foot rests (that is all part of the fender assembly)
gently lift the fender assembly to expose the fuel tank(I have used an engine crane type lift to do this)
remove the bracket over the tank
remove the tank
reassemble in reverse order.
If this helps please vote yes, Thank You!
Posted on May 05, 2011
Sears 21 h.p. lawn tractor
Sounds like a safety interlock. Was there any electrical wires going to the deck, to the engage switch, the up down lever? There is a neutral switch that is closing or opening and the circuit is shutting down the motor.
Feb 08, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftman 42 inch silver lawn tractor and would like to change the oil what typpe do i use
Briggs & Stratton engines use 48 ounces of SAE 30 oil & Kolher engines use 2 quarts of 10w30 oi. Be sure not to over fill the engine will smoke like a banshee!! Verify the level with the dipstick. Oil can be gotten from Sears or from your favorite auto parts store.
Oct 28, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftman Lawn mower continues to burn oil at a fast rate
Are you getting a lot of smoke? If so the oil is getting past the rings and burning.
Jun 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Hook up snowplow to craftman
Go to sears.com and click on the PartsDirect link at the top. Put in the model number of the blade and you will see the diagram of the blade and brackets.
Jan 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
