Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
Pride gogo think is in freewheel when it isn't
It keeps beeping 5 times which is for the freewheel alert even though it is not in freewheel. What is causing this?
  • Pride Master
  • 9,783 Answers
There is a micro switch that the lever engages to tell the controller the position of the lever. It's either not closing properly or is defective.
Posted on Sep 03, 2017
2 Suggested Answers
SOURCE: I have a Pride Gogo 3 wheel scooter. Suddenly I
the lever at the back may be slack and missing the turn-point. Try moving up and down a few times, very gently, this may get the correct position,.
Posted on Sep 14, 2009
We just changed batteries. When we put the key in, there are 5 beeps and nothing will move.We have pushed the brake lever on the back forward and still nothing.
Hi I have no data on the go go ...if the circuitry is similar to pride x the 5 beeps mean the manual lever is in freewheel u have to remove key put freewheel lever in drive & replace key good luck
Jan 20, 2016 | Pride GoGo Elite Traveller 12amp Mobility...
Battries fully charged, turn key on and only beeps 5 times. Thats all.
hi Hal, that is a issue around based the brake or connectors to the brake or the micro-switch that is moved when you move the drive , freewheel lever.. ... firstly make sure the scooter is in drive mode and not free-wheel mode ., where the axle comes apart you will see a number of connectors , make sure they are a good fit ...
Update me please...
Regards
Rob
Oct 29, 2015 | Pride Mobility Products GoGo Ultra X...
The only lever is the 1 in the back then is in the back position, keeps scooter still. Pushed reset button, nothing happens. It still beeps 5 times, it is a pride go go ultra x 3 wheel, please help
Hi, 5 bleeps implies the issue is related to the brake, check the little micro-switch situated on the side of the brake unit , this can stick fooling the scooter into thinking it still in freewheel mode...
if the rear disconnects away from the frame , check the connection here as well.
Regards
Rob.
www.gewizrepairs.co.uk
Jan 19, 2015 | Pride Health & Beauty
My Pride GOGO scooter is stuck in drive and wont go into freewheel?
The park brake has got stuck, the brake needs to come off and be stripped down and cleaned, this will sort it.
Jul 25, 2014 | Pride Mobility Products GoGo Elite...
Have GOGO scooter, when you turn it on the alarm sounds and will not to anything, it has been fully charged.
Princess try the freewheel lever make sure its in the drive mode and turn the scooter back on Hope this helps
Mar 26, 2011 | Pride Mobility Products GoGo Ultra X...
I own a Pride Go Go four wheeled scooter. When scooter is turned on, even though batteries are fully charged, the scooter will not move. I have found that if i then switch it off and switch it from being...
Problem seems to be in the brake wiring or micro switch on the brake itself that is causing your problem check the brake and wiring to make sure you have good connections and check if you can see that the micro switch is working correctly. try leaving the switch on and moving the freewheel lever to see if it will reset without turning the switch off if it doesn't and you have to turn it on then off then there is a problem in the brake circuitry signal to the console and you will have to replace the brake/microswitch assembly. Hope this helps
Feb 28, 2011 | Pride Mobility Products Health & Beauty
I HAVE A PRIDE 3 WHEEL GOGO SCOOTER. THE BATTERIES WENT DEAD. I REPLACED THEM AND CHARGED THEM UP. NOW I GET A 5 BEEP CODE WHEN I TRY TO START. IS THERE A LIST OF WHAT EACH CODE IS? THANKS FOR YOUR...
Hi Fred,
Good job on replacing the batteries!
With the go go scooter, a beep code of 5 indicates a solenoid brake trip. This means that the brake manual/freewheel lever may be in the freewheel position. This means that you can push the scooter. Remove the key and push the freewheel lever to the drive position. Restart the scooter and the code should be cleared and the scooter will run. Hope this helps.
Jan 19, 2011 | Pride Mobility Products Go Go Ultra X 3...
Beeps when in drive won't move
How many times does it beep or is it continuous? Should beep a few times (usually up to 9 times), then stop, then beep so many times again, then stop and so an and so forth. Most of the time this is caused by the scooter being in freewheel or THINKING its in freewheel which could be a faulty brake switch. Also, on the GoGo ultra, the battery contacts regularly cause this problem and have to be replaced. They should be splotlessly clean and shiny for the contact to be good.
Feb 15, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
I have a Pride Gogo 3 wheel scooter. Suddenly I cannot get the 'freewheel' mode. Any suggestions please?
Sep 13, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
PRIDE GOGO ULTRA X Beeps and Cuts off
Please make sure your charger is okay, can you try another charger ?
the other thing is , the FREEWHEEL lever can it move itself say when you go down a kerb , what are they replacing ? do you have the part ? send me a photograph if you do ?
Jun 10, 2009 | Pride Mobility Products Go-Go Elite...
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
26 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
