Disable acer powersmart key - Computers & Internet
End key Automatically Pressing
this problem is coming from your browser. Try to restart the browser with the ADD-ON disabled, from Firefox, or Safari, or Chrome, etc. and try again. Go to help in the browser and follow the troubleshooting section as indicated.
God bless you
Sep 30, 2013 | Acer Aspire V3-571G-6602 15.6-Inch Laptop
I have acer 4741g.. but i don't know how to set the bluetooth to enable by default and disable wireless by default
press and hold the Fn key and then press the F3. it will give you the Enable/Disable option for the communication devices such as bluetooth and wireless. You can choose to enable or disable them.
May 04, 2011 | Acer Aspire 4720 Notebook
When i start my acer aspire 3810T notebook on battery mode nothing happens but when i connect adapter and press the power button it starts.. what is the problem? why is my notebook not starting on battery...
Sounds like a very sleek notebook there, Your power management may be influenced by the
PowerSmart button
" located above the keyboard that allows" you "to easily extend battery life. A simple press of the button activates the advanced power savings settings, traditionally a tedious procedure accessed through numerous software-based steps.
This one-button approach simplifies the process."
Your choice may influence the amount of battery life you get. If that doesn't fix it, then I've got no idea.
Sep 25, 2010 | Acer Aspire 3810TZ4505 (LXPE602077) PC...
I disabled the wireless connection by accident how do I enable it again
You probably disabled it by pressing these two keys.
Wifi is enabled/disabled only by pressing both the Fn + F2 keys. (Don't press the + key, just Fn and F2).
Good luck!!
EJ
Sep 03, 2010 | Acer TravelMate 4200 Notebook
Unable to use touch pad....rt clk and slide key
If the laptop is that new, the problem is probably the touch pad "disable" button. Look for a small button just above or near the touch pad and make sure the touch pad is not turned off. If you cannot find the disable button, look in your user manual for the touch pad disable.
Jun 01, 2010 | Acer Aspire 5100-5022 Notebook
Jumping letters on acer laptop when I type
You need to disable the touch pad while typing. During typing your palm can accidentally touch the touch pad causing the cursor to 'jump' randomly resulting in the problem.
You have not mentioned the model but on Acer laptops there's a key in the upper row with a 'pad and finger' figure on it. If the figure is in blue, press Fn together with the figure key to disable the touch pad and then again to enable it.
Mar 31, 2010 | Acer Computers & Internet
Acer Aspire 5738 problems
DUDE..
XCEPT FOR POWERSMART MANAGER,BIO-PROTECTION AND CRYSTAL EYE WEBCAM,
NOTHING ELSE CAN BE DOWNLOADED
FOR THIS PL VISIT DRIVERS FOR 4736...
UR PROB WILL BE SOLVED N THE DRIVER GIVEN WID 5738 IS A MINIMUM DRIVER TO DETECT THE FACILITY
TO USE THE FACILITY DOWNLOAD IT FRM ACER ASPIRE 4736 DRIVER APLLICATION PAGE...
Aug 17, 2009 | Computers & Internet
Disable sound
When you start your computer, you can press a key to get into your bios setup. I can't remember what the key is in an Acer, but it may be the del key or perhaps the F2. In any case, it should tell you at the bottom of the screen which key to press.
Once in the bios, you should go to the advanced settings (if that is an option) and disable the onboard sound. If there is no "advanced" setting, then you will need to look around for that option.
You can always disable the sound in Windows by going into the device manager, find the sound card that is installed, and disable it.
Jan 31, 2009 | Acer Aspire 3100-1405 Notebook
How to disable mousepad?
normally the Fn and F7 key, it's the key with a finger on a square icon, or right click on the touchpad icon in taskbar>pointing device properties and select device settings and then dissable.
Sep 14, 2008 | Acer Aspire 3000 Notebook
Euro key
You can try the free KeyTweak program to remap the euro key or just plain disable it. To remap the key means changing the function, for example you could make the euro key into the Caps Lock key. DOWNLOAD: http://webpages.charter.net/krumsick/
Jan 01, 2008 | Acer NSK8458AN Keyboard
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
