Question about Hitachi 46W500 46 in. TV/DVD Combo
Turns on and off
The TV turns on and off constantly
If I turn the tv off an try to turn if on again the screen is either solid green, multiple colored lines, or is constantly blinking. If I turn the tv on and off, it will eventually go to a normal screen...
The tv having a problems known as a convergence problems,it dying,going to be dead sooner or later.The tv colors lines R,B,G mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dying going to be dead.These parts on the tv convergence board,must replaced these parts to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | JVC AV-48WP30 48" Rear Projection...
Philips TV turns off and on and has a very bad picture
Check electrolytic capacitors on the power supply board for bulged tops.
May 10, 2010 | Televison & Video
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Channel constantly changes on TV
YOU HAVE BAD BUTTONS ON THE FRONT PANEL THEY ARE STICKING OR ARE SHORTED.
Sep 14, 2009 | RCA P56950 56" Rear Projection Television
Tv won' turn on. Green light constantly blinking.
this tv is mitsubichi?
is mit what is the model?
look like bad DM, you need chage The capacitors.
Jan 31, 2009 | Mitsubishi WS-65315 65" Rear Projection...
The tv works however the picture dissapears/ flickers off but comes right back immediately...happens constantly
Picture tube ( CRT ) is defective = re-juvenation may help for
a temporary fix...................................T.
Mar 28, 2008 | Sony KV-35S45 35" TV
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Blue power light constantly on...
possibly shorted crt drive ic on crt board.
Jun 14, 2007 | JVC AV-48WP30 48" Rear Projection...
Hitachi 46W500 46 in. TV/DVD Combo Logo
32 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
