Question about Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 troubleshooting
The voice guidance has stopped working.  It isn't muted and the volume is up.
  • 3 more comments
  • bellepera Oct 27, 2007
    Thanks for the support.  I actually did try using an external headset and it worked.  I thought maybe if I reset the GPS it would fix itself but it didn't.  Is there a way to fix it considering it is working with the headset or should I update like you suggested?
    OH... sorry, didn't read the message correctly... you're right about the answer to Q#1 is no and Q#2 is yes.  I will try to update it like you suggested.  WIll come back if that doesn't work.  Thanks....
  • narnar Nov 12, 2007
    Mine is having the exact same problems. The voice just stopped the other day as I was driving. I just tried a headphone and it works like that. My question is: is there something I can buy and plug in to the headphone jack that would magnify the sound?
  • Anonymous Jan 18, 2009
  • Anonymous Mar 24, 2014
    on the voice guidance , it shows no voices available and no languages available, what should do about this problems?
Touch sensor seems to be misaligned, when I touch the Where to file it opens the one below it "View Map". Nowhere on the screen I touch will open the "Where to" file.
Posted on Aug 17, 2009
  • 113 Answers
1)Does it make beeping sounds when you touch the screen buttons?
2)Can you hear the voice when you listen through an external headset?
If your answer is no to #1 and yes to #2 then you may have a dead speaker.
In the setup screen there is a way to select different voices/languages.  Try a different voice.
When those models first came out there was a problem with the software not recognizing the voice files.  There was a free update done to correct the problem.  If your current software version is less than 5.00 you should update.
Here's the update page:
Posted on Oct 26, 2007
  • Paul Hyde
    Paul Hyde Oct 28, 2007
    Thank you for responding.
    If your answer to Q#1 is no and q# 2 is yes, the update may not solve your problem because the speaker may be physically defective.  However, it's worth trying the update because you might get lucky.
    As a last resort you can try a reset.  With the unit powered off, hold your finger on the upper right hand corner of the touch screen and tap the power key.  Continue to hold your finger on the screen until you get a warning message. Tap "OK" to reboot the GPS.
Can't put in states, no matter just tells me no matches found
Posted on Dec 21, 2007
2 Suggested Answers
SOURCE: garmin nuvi 350
I had the same dismountingproblems with a 360, but i found the solution. When you look behind de GPS-unit at the top of the case there are two little screws hidden. You have to dismount the GPS first to get to those screws. To dismount the GPS, open this unit with the two visible torcscrews. Open the GPS with little force and turn the cap clockwise and it will come loose. Look to the left into the plactic case where the GPS antenne is found. Then put a very small screwdriver in the shaft case (on the leftside you see a little whole 4 x 1 mm). If you put a little pressure on the screwdrive while moving it to the right you will feel a spring. Its working like a springconnection between a watch and a watchstrap. When you dismount the GPS look out for damaging the electrical connection. Then you can dismount the torcscrews and the maincase. When you open the case you 1 screw in the middle in the circuitboard. be very careful everything is very small.
Posted on Jan 08, 2008
No voice prompt when time to turn direction
Make sure volume is up and not muted. Make sure that you have a voice selected in the voice menu. Under settings, make sure that you have guidance checked. When you press the buttons on the screen, do you hear beeps? If not, your speaker could be bad. More sound troubleshooting here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Nov 13, 2015 | Garmin nuvi 780 GPS
Nuvi2550 has no audible voice prompts
have you cked if it is muted? touch the speaker and when the volume control comes up you can see if it is muted
Dec 05, 2011 | Garmin GPS
Nuvi stopped talking. where is the mute button located on the unit?
If you are no longer getting the voice guidance from your gps, then you need to check if the volume is on the highest or lowest. There is no mute button on the gps, it is when the volume is at the lowest it seems muted. Ensure the volume is turned up by adjusting the scroll whell that is by the right hand side of the unit.
If that does not help, then you check the language settings in the unit. Verify that the voice is enabled, by following these steps:
  1. from the 'where to? view map' screen, touch 'tools',
  2. Touch 'language',
  3. Next to 'voice language' you will see 'jill' listed in the blue box on the right (if so the unit should be ready to use)
  4. If you do not see a 'voice' listed in the blue box, touch on the blue box,
  5. Select 'voice',
  6. Touch 'ok' at the bottom,
That should do the work for you.
Dec 23, 2010 | Garmin nuvi 205W GPS Receiver
My Garmin Nuvi 770 has stopped voice prompts
plug your tomtom into your computer and download all the updates which would include voice
Sep 18, 2009 | Garmin Nuvi 770 Car GPS Receiver
Garmin 350 has no voice
The Garmins have a mute option.....check to see if it accidentally got muted
Jun 08, 2009 | Garmin Nuvi 350 Car GPS Receiver
No voice prompts on my new nuvi 750- volume level not muted.
I had the same problem after I had my Nuvi 750 for a few months.  The voice just stopped.  I called Garmin and they replaced it under warranty.
Feb 11, 2009 | Garmin nuvi 750 GPS Receiver
Garmin Nuvi 200 Voice no longer working
Does your Nuvi 200 have a headphone jack? If so, try that with a pair of headphones. If you hear sound, then your internal speaker went bad. It's a known problem with the Nuvi.
- Jim
Sep 04, 2008 | GPS
Text to speech
My GARMIN nuvi 350 - was working for last two years in good condition,all sudden it speech / voice is lost although I tried to reset as well as adjust volume on high.
It is not mute still it does not have speech ?? why all sudden this issue arised ?? Is there any one to support??
Jul 25, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
864 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
