Question about Kitchen Ranges
F9E0 on whirlpool electric range - Kitchen Ranges
Whirlpool stove shooting code F9E0
F9 or F9 E0
Possible Solutions
Reset power to the product:
This code will most often indicate that the appliance is wired incorrectly at the home electrical supply, or at the hard wire connection.
  • If your oven was installed recently (within approximately 3 months), contact a qualified electrician to verify the electrical supply.
During a power outage, if there was an unexpected amount of power supply line "noise" that the control detected as an incorrect voltage amount, the control could display the F9, F9 E0 or PF Error Code. Also, if any keys were pressed before the 10 second delay interval on power up, this could cause the F9, F9 E0 or PF to appear.
  • Power unit down by turning off the circuit breaker(s) for one (1) minute.
  • Power unit up by turning on the circuit breaker(s).
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify oven operation.
Still need help? Call or schedule service.
You may need assistance from a qualified technician. Call 1-866-698-2538 or click below to schedule an appointment.
Schedule Service Online
Feb 01, 2018 | Whirlpool Kitchen Ranges
F9e0 what does this mean displays after plugging range in and it will not clear it’s a whirlpool
try asking the manufacturer since you kept that a secret from us on FIXYA
Jan 05, 2018 | Kitchen Ranges
How do I restart my stove after a F9E0 code flashes?
The control thinks thinks the heating circuit is open was the oven in use when power went out possible one of the leads may have come off or burned off one of the elements I have seen outages damage a lot of controls with oven off try cancel/off, cancel/off then start to go into diagnostic press the 3 or ^ key till you get to errors follow the prompt to reset this my help
Apr 03, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Will not get hot
Thank you for submitting your question. The error code is indicating a outlet mis-wiring issue or control board issue. If the unit has been working fine then it will be the control board.
Here is the part to order.
Whirlpool W10476673 Cntrl Elec AppliancePartsPros com
Apr 06, 2014 | Maytag MER7664XS 30" Freestanding Electric...
Oven is Electrically charged Or Uses LPG domestic Gas?.
GS460 is not the full model number for the range. The range needs both electrical power (120V AC) and gas. The electric power is used for the burner igniter and controlling the range thermostat.
The GS460LEK can be used with either NG or LPG. It came with the NG orifices installed at the factory; a conversion kit needs to be installed to use LPG. (The cap in the regulator also needs to be turned 180 degrees to read LP.) This should be done by a trained installer. Most Whirlpool ranges will have the conversion kit attached on the back of the range near the regulator. See the installation guide from Whirlpool for your model, try https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=m3wLp9EUOpUUfCAXtvB5kw%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
The installation guide for the GS460LEKQ0 is available at https://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%208522956.pdf .
I hope this helps.
Mar 28, 2012 | Whirlpool GS460 Gas Kitchen Range
Kitchen Ranges Logo
12 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
