Question about Creda C362E Electric Kitchen Range
My creda edc 51 grill is not working but oven is
2 Suggested Answers
SOURCE: creda grill will not switch to oven when i shut the door
Model Number TGF334BCWF Gas Stove.....When I turn the burner on the top front right my oven is coming on without me turning the on. What is going on?
Posted on Feb 21, 2009
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Creda oven manual
The heat control knob needs to be replaced. This controls the amount of electricity that foes to the burner. Sometimes the burner itself has too much resistance and will only work when full current is applied. Hope this helps, please post a comment that this is solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
May 10, 2014 | Ovens
Creda Concept Solarglo Cooker. Grill not working. Elements seem ok as top oven works fine. Any ideas gratefully accepted! Thanks in anticipation.
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Feb 11, 2011 | Ovens
Creda fan oven not heating grill is working and light is on in oven
If the fan is working o/k, then the oven elemment has probably failed.
This is located at the rear of the oven compartment behind a removeable cover.
If the fan is not working, then it it could be the timer is on auto, and not on the manual setting. Check your user instructions.
Feb 02, 2011 | Creda Ovens
Creda Europa Oven an Grill Big oven has Stopped working what would be possible causes
do you mean there isnt any power going to it or it dosent heat up or it just gets warm more detail please
Dec 05, 2010 | Creda Europa E010E Electric Single Oven
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
Creda cooker grill not working,elements replaced, still not working. any suggestions?
Could possibly be grill selector switch faulty, or, depending on the model, it is sometimes caused by a faulty main oven door switch.
Please rate my solution.
Thanks.
Jul 29, 2009 | Ovens
Creda grill will not switch to oven when i shut the door
Feb 21, 2009 | Creda C362E Electric Kitchen Range
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Creda C362E Electric Kitchen Range Logo
24 people viewed this question
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
