Question about MSR MAGTEK - READERS 21040108
Magtek offline code s43
What does code mean
MAGTEK 30050400 SIGNATURE PAD SC PINPAD 3 TRACK MAGNETIC STRIPE CARD READER
I was just researching this and from what I can find, that code means that the internal tampering sensor has been triggered, meaning the your device is no longer usable. It either has to be repaired or replaced by MagTek.
Feb 08, 2014 | Magtek IPAD Payment Terminal
Offline code s43
Guest,
I experienced the same problem, which may have been due to either the triggering of the internal tamper sensor or for leaving the unit "dormant" for too long. This message likely means that you need to replace the device. Contacting the representative which sold you the unit is the best way to arrange for a replacement.
In the documentation on page 17 of the the iPad Installation and Operation Manual, http://www.magtek.com/documentation/public/99875382-4.03.pdf, you will also see the following notes:
S
An offline code beginning with "S" indicates a security element failure. This code can be
triggered through severe handling of the device or strong interference by a nearby EMF
source. If you move the device away from any suspected EMF source and the error
continues, the device should be repaired or replaced.
Jul 27, 2013 | Magtek Mag-Tek 30050202
Have a Magtek card reader and doesn't read Emv cards so how do I fix
those readers will read any card with a mag stripe need to have the programing cards to make it work they can be a pain
Jun 02, 2012 | Magtek MT211 TTL TRACK 1 & 2 Magnetic Card...
Using Magtek Part # 21040145 Not working with WIN 7 Is it supported on WIN 7? Do I need to install drivers?
Load the drivers: http://www.magtek.com/support/software/programming_tools/drivers/mtd_opos.asp
Jun 28, 2011 | Magtek BulleT Magnetic Stripe Credit Card...
Mobile offline can't remove
If it says Offline Mode means it locked to Network,you need to Unlock it,get the Unlock code at here
http://www.theunlockarena.com/supported-phones/rs13wp7/ and Unlock it...
Apr 21, 2011 | Nokia 5230 Cell Phone
Need drivers for magtek 21040102 to run it on windows 7
The best tool for keeping your drivers up to date is: driverupdate us Its, easy to navigate (user friendly) and easy to install. take a look
Mar 07, 2011 | MagLite MagTek Mini Swipe Magnetic Strip...
MagTek Card reader is not working with windows 7.
Install the drivers: http://www.magtek.com/support/software/programming_tools/drivers/mtd_opos.asp
Nov 16, 2010 | Magtek BulleT Magnetic Stripe Credit Card...
Instructions and manuals for magtek 21040082
Try http://www.manualsonline.com/ for all instructions and manuals
Jan 07, 2010 | Magtek MSR READERS 21040082 Magnetic Card...
MSR MAGTEK - READERS 21040108 Logo
372 people viewed this question
Top MSR Televison & Video Experts
Electro Med Services...
Are you a MSR Televison and Video Expert? Answer questions, earn points and help others
