Question about Cuisinart Private Reserve CWC-900 Wine Cooler
We need to replace fan on our wine cooler. Only installed 2 years ago ! Model toyon dc brushless fan model no td8020ls
Need to purchase new fan
2 Suggested Answers
SOURCE: Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Posted on Nov 03, 2009
I have a CWC 1600 everything works fine on it but it does not get cold. Everything powers on fine and you can adjust the temp up and down but it just does not get cold.
Your Peltier is most likely shot! You can fix it for less than $10 in about 30 minutes.
Take the back of the fridge apart and remove the fan and aluminum heat-sync. Sandwiched in between the heatsync you'll see the Peltier pad with two wires coming off it. That's what you need to replace. The peltier has a make and model number on it. I would recommend ordering the same make and model. The specs should be 12v DC and less than 5amp and 60 watt draw. Your wine cooler's power supply can only output 5amp and 60watt max power. When you install the new Peltier you'll need to spread new thermal compound on both sides of the Peltier. I recommend Artic Silver Ceramique. You can buy this at your local Radio Shack or any computer store where they sell motherboards and CPUs.
Ceramique Thermal Compound
Apr 13, 2014 | Cuisinart CWC1600 Wine Cooler
Fan runs but it doesn,t cool
New TEC1 12706 Thermoelectric Cooler Peltier 12V Ceramique Thermal Compound
Feb 28, 2014 | Cuisinart CWC1600 Wine Cooler
I am in need of a fan motor for my Danby Frig. Paret #JG50.DQ-10. Cannot find it anywhere. Suggestions?
The problem with the factory fan is that it is a sleeve-bearing fan. On average, a fan should operate for about 50,000 hours, which if it runs continuously would be over five years. However when the operating temperature rises or the fan is installed "not exactly" vertically, it will have shorter life.
I had to replace my fan two times withing two years since we bought the unit! Plus the stock fan becomes quite noisy after a couple of months of work.
With all of these problems I did some research for better fans and decided to purchase a ball-bearing fan to install it into the cooler by myself.
Ball-bearing fans on average outlast sleeve-bearing fans by 50 percent and produce less noise.
It's very important to purchase the right AC 115 Volts fan for this Danby wine cooler.
The original fan is Rullian Science RAL 1225S2 (120x120x25 mm in size, 100-125V AC, 0.09A)
The replacement model is Orion OA12AP-11-3TB which I got for $16.75 from Mouser Electronics (mouser.com). The replacement model is ball-bearing cooling fan with slightly higher/better parameters, which will help to cool down the wine cooler coil faster.
To replace the fan you need to tilt the wine cooler on the side and unscrew two small screws at the bottom that keep the original fan in place, remove one screw to the black box where the fan wires are attached and unplug these wires. Then you just need to replace it with the new fan and test that it works properly. If you never used Soldering Tool before you probably will be better off with getting some help from certified electrician - it still will be less expensive than getting this fan ordered every year from Danby.
Nov 06, 2012 | Danby DWC513BLS Wine Cooler
Noisy fans on a desk-top pc Model Acer Veriton 1000. Besides replacement for new fans, can brushless fans be serviced or lubricated?
The Veriton 1000 I have has 50mm fans (length and width). 80mm are the wrong size. They are 15mm thick, 12V, 0.2A. For some reason, these seem to be more expensive than many other fans.
Jul 13, 2012 | Computers & Internet
I need a 2x2 brushless fan model # rdm5015s dc 12 volt. where do i find one please?
Perhaps try Google's Product Search?
It appears to be a fairly standard 50x50x15mm fan with a two pin type 2 connector. Try looking for a two pin 50mm fan with a thickness of less than or equal to 15mm.
A quick search I've done can be found here.
May 10, 2010 | Sanyo /San Ace DC 12v Brushless FAN Assy
Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
May 04, 2010 | Haier BC112G Wine Cooler
Wine cooler FWC20T is not working , purchased 4/2009
Mike, what I would do is get a stick of dynamite( not really) Go to an appliance parts house with the model and serial # of the unit. You may still be able to purchase the board in question from them. If they can't help you I would find a store that sells wine coolers and ask them. Unless the company you bought this cooler from had a patent on the circuit board then they are mostly generic. You may have to wire the board up a little different but the new board's information paperwork will tell you the wiring diagram for the unit.
Good luck hope this helped you in some way
Dave
Jan 29, 2010 | Refrigerators
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
I purchased a Coleman model 564 cooler about june 1,2008 at Wal-mart. I used it for two trips to Canada,June and August,one week each. The fan operates spasmodically and the unit does not cool. I believe...
I had the same problem with the fan...its junk.. don't try to replace it with the same kind of fan. I went to radio shack and got a 3.15"square brushless fan. You could go to a computer store and get the 3 &5/8" fan with ball bearings and it would fit just like the old one. Fans run about $15 to $20 depending on location. I cut the old one out and sodered the new one in and it works fine now. Hope this helps. Larry Crockett at crockett2242@yahoo.com Let me know how it works.
Aug 28, 2008 | Heating & Cooling
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Cuisinart Private Reserve CWC-900 Wine Cooler Logo
70 people viewed this question
Top Cuisinart Furniture Experts
Maxumized
Rabbit Brains
Rabbit Brains
Are you a Cuisinart Furniture Expert? Answer questions, earn points and help others
