Roland MMP-2 2-Channel Amplifier Logo
Posted on Jun 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When plug in guitar to amp, there is either no
When plug guitar to amp, there is either no sound or a loud overtone. The problem seems to be the amp because when I plug my guitar into other amps, it works...though intermittently. What could be the problem?
Anonymous
Level 2:
  • Expert 73 Answers
  • Posted on Jun 13, 2009
Anonymous
Expert
Level 2:
Answers
73
Questions
0
Helped
27059
Points
130
Try a different guitar and cord. If still problem, give the amp a bump without guitar plugged in. If amp makes noise, there is an intermittent internal connection,
Paul
2answers
My peavey valveking 212 feeds back when the gain button is pushed it makes a loud whistling sound with nothing plugged in
Turn your guitar away from the amp's speakers. The pickups on the guitar are feeding the amp's signal back into the amp creating a feedback loop, especially with the gain button on. Loud volumes cause this looping path between the amp speakers and guitar pickups. You may need to reduce amp volume also.
I plugged my guitar into the amp one day only to get no sound from the guitar. The amp is working - I plugged a different guitar in and it worked - but the guitar seems unresponsive.
If the guitar is active and the battery is dead you will not get any sound. If the output jack or some of the controlls have been twisted and may have broken the connections on the inside.
The active light does not light up when I plug my guitar in and no sound comes out from the talkbox ... But the guitar sound can run through it to an amp where the guitar sound comes out
It sounds like you have NOT connected the power adapter to the box to power it. The guitar sound won't be too loud as you run the hose to your mouth and pick up the sound with a microphone such as a Shure SM57 which then goes to your amplifier. Without the power adapter the internal amplifier will not produce any output.
I have a Marshall MG100DFX. I turned my amp on a few days ago and I heard this loud sound (not the standard hum/buzz that you hear when you plug a guitar into an amp; it sounded more like a foghorn). Now,...
I would try hitting the side of the amp before turning it on. There may be a loose piece of solder or other conductive particle stuck somewhere. Bang the cabinet rather hard with your fist. If that doesn't help it might be a loose solder connection at a resistor or capacitor but a tech should check that out.
2helpful
2answers
Loud humm when the drive channel is on
I suspect the power supply has an issue. Most likely bad filter capacitors. This could cause "motorboating" where power is drawn and supply voltage collapses and then recovers repeatedly.
Time for the repair shop. The parts cost should be nominal... labor... well...
Hi, i just bought a gnx-3 guitar processor and it hums loudly.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad cable or pickup. Set the volume to a level that you can tolerate. You may want to turn off the amp between each of these steps. Unplug the cable from the amp; if the hum does not go away you have problems with the amp. If it does then plug the cable into the amp and short the end that plugs into the instrument. If the hum goes away it is the pick system in the instrument, if not you have a bad cable.
Good Luck
Gilshultz
4answers
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 • Music
3answers
Guitar Problem I Think.
First check your guitar to amp cord.
The pickup, audio jack, or pickup selection switch may be defective.
2answers
Crate RFX65 solid state guitar amp has power but no sound
Hikonartist87
Sounds like the amp has developed a problem. If you had it LOUD then you may have popped a speaker or an output stage. You say it still makes the plugging in noise, what happens when you touch the end of the jack lead whilst plugged into the amp. do you get a burst of clean hum?
regards
robotek
Top Roland Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
