Question about Crosley 0187SST Turntable
I have a Crosley Keepsake and the turntable is running a bit faster which makes my records go a tone higher. Do you know how I can solve it?
  • 157 Answers
SOURCE: Crosley traveler turntable noise
Hello attaboy. You may need to check you ac cord if the noise is in turntable, radio, & cassettte mod. If it has a 3 prong plug than you are missing a GND connection, in the cord or inside the unit. If it has a 2 prong plug than take it back or open it up and replace filter capacitors or bridge rectifiers in units power supply.
Posted on Sep 19, 2008
freetek
  • 5568 Answers
SOURCE: new crosley CR249-GR "wow and flutter"
I see your message isn't new anymore but Crosley does have a website with warranty and support info:
Crosley Radio
Posted on Aug 15, 2009
  • 84 Answers
SOURCE: My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Posted on Nov 25, 2009
  • 8404 Answers
SOURCE: Just got our Crosley cr249 turntable for Christmas
Increase the pressure on the needle.
Posted on Dec 26, 2009
Grubhead
  • 5484 Answers
SOURCE: I have a Crosley Keepsake turntable which plays 33
The only thing (I think) that would cause a 45 to play badly and the 33 not, is either the cartridge or stylus, most likely the stylus. It's either worn or damaged, so it fits badly in the larger grooves of 45's then the smaller ones of 33!
The signal coming from the cartridge is the same on 45 as it would be from 33.
Posted on May 25, 2010
Can anyone help me with grounding a Crosley Keepsake turntable? I have run a wire down the tonearm, when I touch the end of this wire the hum goes away, I just don't know where to attach it?
antique turntable that had an earth wire on it too. I just found a screw on the back of the turntable and fitted the wire under this screw, It worked a treat and the hum disappeared.
Feb 03, 2016 | Crosley Audio Players & Recorders
My turntable a Crosley CR49 is about 14 years old. It plays just fine, but have to manually reset, clicking the tone arm after every record I play, either 45s or 33 1/3. How Can I fix this?
You will need to get to the underside of the turntable. There you should find that the arm when it gets to the centre of the record it will push on a switch. This switch might be out of position or just get stuck by grease or dirt. Correcting it should solve the problem.
Dec 08, 2015 | Crosley Audio Players & Recorders
My crosley keepsake turntable has been having a lot of static and the sound is very low, I can only hear it if I turn the volume all the way up. I'm not sure if the needle is the problem or there is s
I would check the wires to the cartridge. It might that one or more is off or loose.
If you turn down the volume completely and listen with a record playing you should be able to hear (with your ear) the stylus in the grooves of the record playing the track. Pick a loud (rock) record for this. If it does that OK the stylus is good.
Dec 26, 2014 | Crosley Keepsake USB Turntable
Why is my brand new crosley turntable keepsake hunter skipping tracks?
The turntable may not be level. Also, the stylus could be damaged or defective. The stylus pressure may not have been set correctly in production or may have been affected by shipping.
May 05, 2014 | Crosley Keepsake USB Turntable
Crosley Turntable Repeating little bits?
Is this on all records? if yes! you need to adjust the weight slightly, if the problem is with one record, clean the record in luke warm water and dry carefully, may solve the problem.
Apr 16, 2012 | Crosley CR49 Traveler Portable Turntable...
I have a Crosley Keepsake turntable which plays 33 1/3 rpm records perfectly. However, when I try to play 45rpm records the sound is very distorted, especially the vocals which sound as though they are...
May 20, 2010 | Crosley 0187SST Turntable
Crosley 0187SST Turntable Logo
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
