Mita 2020 c6 - Office Equipment & Supplies
How to solve c6 error code problem
I'd you wiah to get some details about printer repair and service then check the following link.
http://electro-medical.blogspot.com/
Jul 24, 2016 | Kyocera Mita Toner For Kyoceramita...
E32 error in kyocera
The toner container is not installed on the copier.
Mar 01, 2016 | Kyocera Mita 2 Pack Km 2020 2035 2050...
How do I fix error code C-6 with a KM 2020 copy machine
It is resettable to enter simulation so .....
Press and let down "Clear / Stop", "Start" button on the left to darken or clear, then "Stop / Clear" "U163", "Start" appears "CLE" and there you hit "Start" other time and now.
Feb 22, 2015 | Kyocera Office Equipment & Supplies
Error code c6
heater problem reast 10871087 after selct 163
Aug 07, 2014 | Kyocera Mita 2 Pack Km 2020 2035 2050...
MY MITA DC1205 WILL NOT TURN ON FAULT FLASHING ''C6'' ANY IDEAS?
You might have a broken transfer charger wire or shorted out corona blocks, It is the piece that sits underneath of the drum
Jan 07, 2010 | Gestetner Office Equipment & Supplies
Mita photocopier DC 1205 won't turn on
That's a very old machine, most likely the power supply is cooked. I know I replaced a lot of them back in the day. A machine at that age, and capablility, is much cheaper to replace than repair these days
Jan 29, 2009 | Office Equipment & Supplies
Kyocera Mita KM 1500
Still sounds like there is a problem with the fuser unit. The technician that replaced the parts should be able to troubleshoot the problem.
C6 = Fuser error. The unit is not heating up due to a bad Fuser lamp, fuse, or thermostat, or bad thermistor.
The circuit is open, and the machine won't work til the problem is repaired. Once open circuit is repaired/closed, the machine should reset on it's own after you power the machine down and back up.
Does the machine flash the C6 right away as soon as you turn it on OR, does the C6 show up after about 3-5 minutes?
If you get the C6 right away, then the circuit is open, and that needs to be fixed.
If you get a c6 after 3-5 minutes, then there is a good chance the lamp is bad.
Hope this helps.
Good luck
Feb 08, 2008 | Video Cameras
12 people viewed this question
jasbo
jasbo
