Question about HP Office Equipment & Supplies
How to fax on hp 5535 - HP Office Equipment & Supplies
Why did it stop printing?
If you did not use a genuine HP product for your HP printer the printer is programmed to reject it and, in some models, are programmed to disable the printer so it is no longer usable.
Dec 01, 2015 | HP ENVY 5535 E-ALL-IN-ONE PRINTER
How do I undo/remove scan from hp envy 5535 printer to hp envy 20 computer?
The scan is just a file on your computer, search for it an delete it.
You can search by date or type.
See scanner defaults as to where it stores the files.
Mar 06, 2015 | HP Black Envy TouchSmart 20-d13w...
Why does my hp envy 5535 stops in middle of print job
Please try following the steps below and let me know if that may help:
  1. Open the HP Envy 5535 software, then click the Printer Home Page (EWS) link.
  2. Click the Network tab.
  3. Click Networking , and then click Network Address (IP) .
  4. Click Manual IP , and then click Suggest a Manual IP Address . A manual IP address, Subnet Mask, and Default Gateway displays.
  5. Be sure to take a note of the IP address and Confirm the changes, then close the EWS page.
  6. From the HP Envy 5535 sotfware click the Utilities tab, then click on Update IP Address.
  7. Type the manually configured IP address, click on Save and confirm.
  8. Open the control panel and go to Devices and Printers.
  9. Right click the HP Envy 5535 icon and select Printer Properties.
  10. Open the Ports tab.
  11. Click teh Add Port button, select Standard TCP/IP and click on New Port.
  12. Follow the steps by typing the manually configured IP address and confirm the changes.
Read More... HP Printer Support
Thanks,
Jul 23, 2014 | HP ENVY 5535 E-ALL-IN-ONE PRINTER
How do load paper in printer?
Load a stack of paper in the main tray: Load a stack of paper in the main tray. The main tray can hold and auto-load multiple sheets of paper. Load only thin, flexible media into this tray, because the paper bends as it passes through the printer.
I share a link please read full guide line, i hope solved your issue.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c00630201
Thanks,
HP Phone Number
Jun 18, 2014 | HP ENVY 5535 E-ALL-IN-ONE PRINTER
Will an ACER 5535 15.6" Screen Work in an Acer 5735
Check the part number on the rear of the screen. If not identical it might not work.
Apr 07, 2014 | Acer Aspire Computers & Internet
Locating the motherboard battery for Acer Aspire 5535
i think, it is under the fan, but it is glued in something ? maybe you can remove the keyboard, and clip of that blue/white cable on the left to flash the bios ???
Jul 21, 2012 | Acer Aspire 5535-5050 Notebook
I have a ricoh ft5535 copier. When I click copy the display panel reads, "misfeed remains inside" and the area "A" light comes on. There is no paper in the machine anywhere.
This alert can result from the smallest portion of a paper misfeed. Open all doors and look into each roller corner for a piece of paper that may have been jarred into a corner.
Dec 31, 2010 | Office Equipment & Supplies
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
My aspire 5535 crystal eye webcam shows me upside
Hi, Try Reinstalling your Drivers for your cam.
Thanks
Feb 07, 2010 | Acer Aspire 5535-5050 Notebook
35 people viewed this question
Seeker5211
Seeker5211
