Question about HP Compaq DC7900 PC Desktop
Hp compaq dc7900 5 beebs - HP Compaq DC7900 PC Desktop
I have a constant beeb beeb ----beeb beeb---beeb beeb from my speakers or headphones but not from the computer tower when the speakers or headphones are removed. Is this a audio problem with PC or a virus?
Hi there
A couple of points.
Many system boxes no longer have built in speakers, and if they do they are very simple and simply used for POST errors and other alarms eg CPU fan failed, overheating etc. If there is a pattern to the beeps, you need to check against your BIOS codes to ensure nothing serious is happening.
If your system is working completely normally otherwise, then I would suspect an audio problem, which might be resolved by removing and re-installing the audio driver from the disk supplied.
Cheers
Nov 10, 2014 | Computers & Internet
There is no beep or display on p985h
Have you checked if the processor is getting heated or not?
Check the voltage at ram 3rd pin. It should have about 2 volts.
Check it proessor and without processor
Nov 09, 2014 | Compaq HP DC7100 Usdt P985H System Board...
Boot and work but no beeb
use your software utility coming with your compaq, the administrator utility, and restore to the factory adjustment. and fix it.
God bless you
Oct 22, 2013 | Compaq Presario Notebook
Boot and work fine but no beeb or sound
go to control panel, and use the utility System RESTORE, and put the last days that you know was working Good. and fix it.
God bless you
Oct 22, 2013 | Compaq Computers & Internet
My laptop is not turning to on
Seems to be problem in the Ram.
Step 1: Open the back cover where the RAM is located and take out the Ram and clean it with a soft brush and insert it back.(be careful while inserting the Ram coz you might damage it. insert it at an angle of 45 degree.
Step 2: If that didnt work then take out the Ram again and listen if there is and beeb sound. if there is the problem will be with the Ram Try changing a different Ram.
Step 3: If step 2 dosnt show and beeb sound then its obvious that its broblem with the motherboard(northbridge) or the display system.
Try Consulting a pro.
Sep 27, 2012 | HP Compaq nc6230 Notebook
Computer won't turn on!
what it might be is that your hardrive or power supply is not working and that you need to have it replaced
soory i couldnt be of more help!!
Jul 22, 2010 | HP Compaq d530S PC Desktop
My dv6000 dont start . i have black screen with one long beeb and two short beebs
That code means that the display adapter is bad. Replace the display card.
Mar 23, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Hp dv9260nr 4 beebs, black screen. can i fix or replace video
from what i know about laptops, their VGAs cannot be replaced because they are built into the Mobo so the best solution there is to consult a laptop techinician. He could just reinsert or clean the contacts that could cost cheaply.
Sep 23, 2009 | HP Pavilion dv9260nr Notebook
Problem withPanasonic phone
Unplug the power supply to the phone, wait 1 minute and plug it in again
Mar 05, 2008 | Lands Phones
HP Compaq DC7900  PC Desktop Logo
19 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
