Question about Kitchen Ranges
Yeoman Gas stove pre-2005 need parts
I have a Yeoman Exminster gas stove which cuts out after 15 minutes. The original company, Yeoman, ceased trading around 2005 and although Stovax took the name over and continue to make the same named stove, it apparently doesn'thave the same internal parts and so can't supply parts for mine. No local or indeed, suppliers from England have any parts or suggestions. As it has had very little use in all the time we'vs had it, it seems such a huge waste for want of a suitable flue sensor (I and the gas guy that did look at it think!)
    Top Expert:
  • Kitchen Ranges Master
  • 23,166 Answers
One would think that a sensor is a sensor.
I would contact Yeoman and make enquiries.
Gas Stoves Yeoman Stoves
Posted on May 09, 2017
  • 213 Answers
SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Posted on Nov 21, 2007
  • 833 Answers
There is nothing fancy about how the gas controls work on this unit. Do all burners give you the same problem? If so, it could be a kinked service hose or a service valve that has been partly shut. If it is limited to a single burner or two, the valve may be gummed up and should be replaced.
Posted on Dec 13, 2007
rickzilla
  • 706 Answers
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
  • 11 Answers
SOURCE: General Electric stove top burner does not light
Sorry for apparently not giving feedback earlier, but the gas valve on the one burner has been replaced, and that solved the problem. What apparently caused this is someone forcing the knob in the reverse direction that broke something in the shaft. It sort of worked for a little while, then would not work at all... no gas coming out = no ignition. I replaced the gas valve with the suggestions given above and all is well.
I you are having problem with your unit, check to see if gas is coming out at all from the burners...you will be able to smell it easily. Then find the pinhole on the side of the burner that is used to ignite the burner when the spark is sparking. clean this pinhole out with a toothpick or small wire...really make it clean as small obstructions can prevent it from working. Then clean off the small electrode with fine sand paper and use the toothpick to remove any food particles on the electrode and the insulator around it.
Now looking again at your comment - no ignitor-... if this means no spark, clean the electrodes ...if itstill doesnt work , one of the gurus can specify the component that generates the spark(s) and troubleshooting procedures for that.
To the person who had no gas, that sounds like a main gas valve problem (regulator?)... resend that question to the gurus as you seem to have something blocking the regular flow of gas for the whole unit.
good luck
Posted on Sep 25, 2008
SOURCE: We own a Eurogas 900mm
I have the same stove but do not have a problem with the oven door hinges but rather the glass cooker hood hinges--although my knobs are starting to burn. Both hinges have popped in separate occasions and both times I have called the Cape Town agent foo Eurogas and had fantastic responses from them. http://www.eurafrican.co.za/contactus.html
Posted on Jan 19, 2009
Gas smell when using and not using
follow this steps and fix it. God bless you
f the pilot light on your stove goes out, natural gas may build up in your stove. If your pilot light has gone out, open the kitchen windows and doors for 15 minutes to let the gas dissipate safely then relight the pilot light. Do not relight the pilot light immediately -- striking a match could cause an explosion.
Gas Leak
  • If you can smell the sulfur-like or rotten egg smell of gas, there may be a gas leak inside or outside your home. You might also hear a hissing sound coming from the stove or another appliance or from a pipeline. Outside gas leaks may kill or stunt nearby vegetation. Signs of carbon monoxide poisoning include nausea, dizziness, fatigue and other flu-like symptoms.
f you still smell gas after relighting the pilot light, don't hesitate. Leave your home, along with the rest of your family and pets, then call your utility company or 911 from a safe location. Leave the doors and windows open behind you, especially if the odor is strong or you can hear the hissing of a gas leak. Do not turn appliances or lights on or off or use a phone in your home. Do not strike a match or use a lighter, either. Prevention
Read more: http://www.ehow.com/info_12193884_smell-gas-house-still-lingering-after-shut-off-stove.html#ixzz2aT2VTMtc
Jul 28, 2013 | Maytag MGR5752BDS Stainless Steel Gas...
What is a canister stove?
Canister stoves run on pre-pressurized gas canisters. The only thing you need to do is to simply attach the stove to the threaded fuel canister turn the gas knob and light it with a match.
Sep 10, 2012 | Coleman Camping, Backpacking & Hiking
Mgrh752cds gas stove switched back from LP to Natural Gas
http://www.partselect.com/2084108-3-M-Whirlpool-74006429-Gas-Pressure-Regulator.jpg
This is the part you need. It will have instructions with it. Order this part from repairclinic.com because you really don't need it, just the directions with it, and after you switch back to gas, just send it back for a 100% refund.
Jun 04, 2012 | Maytag MGRH752CDS (Gas) Stainless Steel...
Bought second hand lady lost installation instuctions yeoman gas fire stove serial number 61363
I can almost definitely supply the installation instructions for you, however I need to know the model of the stove as the serial number doesn't actually identify it to anyone other than the manufacturer.
Some manuals with installation instructions can be downloaded by visiting the following page:
http://yeoman-stoves.co.uk/technical/instruction_manuals_%20index.htm
If your manual is not in the list, please post back with your model (this is usually a name, e.g. Exminster or Devon Double) and I will obtain the installation instructions for you if they are available.
Hope this helps.
Regards,
BElectric
Nov 19, 2010 | Heating & Cooling
Stoves 900DFa oven cuts out
Hi.
The most probable cause is failure in your panel cooling fan 9not the one inside your oven)
If the appliance switches on again after 15 - 20 minutes then the fault is most likely here.
Unfortunately as you have gas the you will need a Gas Safe Certified engineer to repair
Regards
aardvark repairs
Nov 18, 2009 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Hotpoint gas oven 5yrs old pre heats fine but then doesn't keep temp up.
You have either a faulty oven thermostat, or your oven door seal is faulty. You can check the oven door seal by doing the following (you will need a A4 piece of paper):
Open the door put the paper against the seal, close the door. Now pull the paper slowly out, if there is resistance then the seal is fine.
The oven thermostat test is as follows (you will need a stopwatch):
Turn your oven on to the lowest setting,when it goes to high flame start timing it the oven should cut down within 8 minutes, if this doesn't occur your stat is faulty.
I hope this helps
Jul 06, 2009 | Frigidaire Gallery 30" Self-Cleaning...
Electrical fire in stove
I would call the gas company and have it checked out in case you had a gas leak on the stove which may have brunt the wires , it safe with the gas and elec off,
Jan 04, 2009 | Frigidaire FGF326AS Gas Kitchen Range
Gas oven makes a fluttering sound when pre-heating and cooking
This is most often due to the ignitor bar aging. With time it draws less current and does not hold the regulator valve open all the way. You can confirm that the regulator is OK if the broiler works. Replacement for nearly all of these ovens is a universal part, about $35 at appliance parts stores, takes 5-15 minutes to change (depending on whether you need to pull the oven out to get to the connector).
Nov 30, 2008 | Kitchen Ranges
Ge spectra gas stove top not lighting
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
