Question about Canon imageRUNNER 6020 Copier
Canon 6020 error code E000354 - Canon imageRUNNER 6020 Copier
How do i fix error 000121-000?
According to the manual which I have put here under printers and copiers "If the job or operation does not complete correctly, check the End Code, and
perform the necessary operations according to the End Code displayed. You can
check the End Code in the Details screen under Log in the System Monitor screen.
(See "Checking Job Details," on p. 2-8.)
canon imageRunner 6020 Reference Manual Reference Manual List Of Error...
Feb 01, 2015 | Canon imageRUNNER 6020 Copier
Error code h2
Pre-exposure lamp
Does the pre-exposure lamp turn on during copying operation?
Check the wiring from the DC driver PCB to the pre-exposure lamp; if normal, replace the pre-exposure lamp.
Nov 16, 2013 | Canon imageRUNNER 6020 Copier
What is cleaning web?
i have canon image runner 2420l .
i have paper jam error in my machine while there is no paper in the machine how i fix this error.
Oct 01, 2013 | Canon imageRUNNER 6020 Copier
ERROR CODE E000354-0002
A Canon IR5055 is gaving me a error code 000354-00002. Can some one gave me the solution.
Oct 31, 2011 | Canon imageRUNNER 3225 Black and White...
IR2520, error code E0002
it is related to fixing unit.
check your fixing unit.
Apr 17, 2011 | Canon imageRUNNER 6020 Copier
My Canon 6020 flashes "E" and "001". What does
E001 error is thermo fuse and/or fuser lamp error. This is the source of heat for melting the toner into your copies as they come out the machine. Probably requires a service call.
Jan 29, 2011 | Canon Office Equipment & Supplies
Nokia 6020 Master code did not work
Hi
have you tried 123456? this is the default code for most nokia phone- unless you change it to something else.
Dec 19, 2009 | Nokia 6020 Cellular Phone
Canon ir3300 code E000354-0002
Yep, that's problem. The manual and the Canon Tech Support website say this code does not exist. Although if it were a valid code it would fall into a series of codes that indicate tampering with the architecture of the the device. Certain ciruit boards are "married " to a series of machines "2200, 3300, 3300i etc" and when mixed and matched can cause conflicts. Serial numbers are compared, engine speeds. This is in an effort to make sure a copier with 2 million copies can't have its "odemeter " rolled back. Or to make a 22 copy per minute machine run at 33 copies per minute simply by changing cicuit boards. Again this is speculation as the code you indicate does not have an explanation or description. That is truly a more accurate statement as there are certain error codes that exist that only R&D and service engineering use that typically would not occur in the field. Therefore the explanation of the code is considered unecessary.
Jun 04, 2008 | Office Equipment & Supplies
Canon imageRUNNER 6020 Copier Logo
old marine
old marine
