Question about Aprilaire Model 8600 Thermostat
Aprilaire thermostat and power outage
I have a backup generator, but the thermostat keeps reading power outage... How do I bypass to run heat
Where is the backup battery?
portable battery backup power supply for macbook pro and air
www.clubfidelis.com/news/index.php?q...battery-backup-power...air
PORTABLE BATTERY BACKUP POWER SUPPLY FOR MACBOOK PRO AND AIR: PORTABLE BATTERY BACKUP POWER SUPPLY ... HT201700 I need a portableback up battery for my MacBook Air 11 . ... air purifiers that controls mold.
Battery Powered Air Purifier - Wag.com
www.wag.com/html/sg/battery-powered-air-purifier.html
... 365-day return policy. Buy Battery Powered Air Purifier at Wag.com. ... MarinaBattery Operated Air Pump .... Penn-Plax Air-Pod Battery Back Up Air Pump.
Amazon.com - Mini Portable Battery Air Purifier Air Ionizer ...
amazon.com/exec/obidos/ASIN/.../amztowps-20
Amazon.com, Inc.Amazon.com - Mini Portable Battery Air Purifier Air Ionizer For Small Areas - BatteryOperated Air Purifier.
Jan 05, 2016 | Air Purifiers
New a/c - furnace installed, no instruction manual, it is 23 degrees outside, and I have no idea how to turn on heat instead of a/c. Need thermostat instructions.
Usually just put the thermostat fan on auto, the a/c heat switch to heat and set the temperature where you want it. If it's a gas furnace, you will need to light the pilot. Usually instructions are on the furnace door, maybe inside furnace door.
Dec 05, 2013 | Air Purifiers
Where is the thermostat?
a thermostat is always located on top hose from radiator.. just follow ur hose from radiator to engine block when the hose stops then u found it i have not seen a thermostat been any where else, as i been working on cars 9 years ...
Sep 29, 2012 | EBC Brakes 2000 Chrysler Concorde - 3.2L...
I have an Aprilaire 700. Whenever the unit has been turned on, the water flow to the unit will not stop running. What part(s) do I need to replace so that the unit will properly turn the flow on and...
Hello, in order for the humidifier to turn on and off with the furnace you need either a sail switch or current sensing relay. A sail switch mounts in the return air duct and senses the return air when the furnace turns on thus turning on the humidifier and turning it off when the airflow stops. A current sensing relay works the same way but instaed of sensing airflow in senses current on the blower motors common lead and is easier to install than a sail switch. I will post a pic of both
robhvac47_24.jpgSail switch
robhvac47_25.jpg Current sensing relay
Feb 27, 2011 | Aprilaire Air Purifiers
Trouble indicator came on after a power outage and
When was the last time the backup battery was checked? The trouble indicator could mean a weak or non-working battery. If the system is 12 years old, the battery should be changed.
Mar 07, 2010 | Air Purifiers
New filter causing eye irritation?
There were some problems where people used glas-fiber-islations as a filter (it could be yellow or white), the problem generated because air filters and isolations camed in more or less same packageing (people didn't know, or couldn't know the diference) if u rub the new filter and it starts hurting or burning finger's you have isolation, if not there could be a problem with chemicals that where in filter fiber's, you can leave it on sun for a few hour's and bring it back in
this is the best i can do to help you
Dec 27, 2009 | Aprilaire Air Purifiers
Evcon Model EB15B Elements glow red for 3 minutes then cycles off. Fan stays off during the cycles. Manual fan switch will turn on the fan. Assistance requested, cls
the fan has to be on while the strips are on. knowing that the fan comes on when you switch it to on at the thermostat but not when your just calling for heat indicates that you have somting wrong with the heating relay or the fan isnt wired properly to the heating relay (posssibly a new motor during the summer) or just a bad relay. when the first stage heat comes on it should also energize the motor the first to come on is also the last to shut off which will make sure the fan runs during the whole heating cycle. until you remedy this you can run the heat just keep the fan switch set to on so its running, this will not hurt anything
Nov 24, 2009 | Air Purifiers
I replaced a Lennox DSL-450LX heat pump thermostat with a Honeywell RTH3100C. Everything works except the gas does not ignite when set to emergency heat. The Lennox was wired as follows: W = white wire Y1...
Hi, If indeed you do have a heat pump, there wouldn't be any gas involved as a heat pump runs on freon with a reversing valve and heat strips for aux and emerg. heat. For gas electric operation thermostat terminals are rc to rh with factory jumper. Red wire to either.W to W for Heat, Y to Y for cooling G to G for Fan. If you have a blue, you wont need it unless this is a commercial stat useing a common for the Led lights on the stat. The unit will get its 24volts through R terminal in combination with y,w,and,g. Cant be a heat-pump if you have a gas furnace.Wrong t-stat. You need a gas /elect stat. And on a 24volt programmable t-stat, the batterys are used for the program only.If the batterys die, than you will loose the program on most residential stats. On commercial stats with the common in play, when batters die the stat defaults back to the factory settings.If you had a Lennox heat-pump stat on a gas/elect unit, you need to change it. Someone was using what they had on hand. Let me know if this has helped you.I will be here if you need me. Sincerely,
Shastalaker7
Nov 17, 2009 | Air Purifiers
Shortness of breath, coughing when working out near unit.
I think you've answered your own question: "symptoms cease when unit is turned off".
I don't want to be alarmist, and I certainly do not suggest that there is anything unsafe about the Breeze AT.  Nevertheless, this machine generates ozone, which is an upper respiratory tract irritant.  It is absolutely vital that you follow the manufacturer's instructions to the letter when operating it. Personally, I would never want to be in the same room as a working ozone generator (and I know of at least one ozone generator where the instructions specifically tell you to keep out while it's working).
Your machine may be on a setting where it is producing more ozone than is desirable. If you no longer have the manual, you can download a copy at www.ecoquest.com (click on the DOWNLOADS tab, then on OTHER on the green bar. The Breeze AT is in the Owner's Manuals list.).
If in doubt, play safe!
Mar 05, 2009 | Ecoquest Breeze AT Living Air Purifier
Aprilaire Model 8600 Thermostat Logo
172 people viewed this question
Top Aprilaire Air Purifiers Experts
Are you an Aprilaire Air Purifier Expert? Answer questions, earn points and help others
