Samsung Syncmaster P2350 Backlight turns off seconds after on
Samsung Syncmaster P2350 always turns off just right after having it turned off. The Power light touch buttons and LCD Panel work. ITs just the Light tubes that turn off. In the beginning the problem was very infrequent - not detactable by Samsung Lab. When it was frequent enough the P2350 was out of warranty already. So I am looking for a solution here. Thanks a lot in advance!
SOURCE: Viewsonic VX900 turns on for second then shuts off
I had to replace a fuse(F1) on the inverterboard of my VX900 to get it back to life as fuzzytek sugested.
It was replaced by a normal "flat" fuse (for cars). Had no clue about the value, so I tried with 0,5A first. It blew right away. Next value I had was 2A, and it worked! (It might be too small, and it might be too big, but I think it is better to usa a "large" fuse rather than no fuse at all. :)
Some pictures from my installation:
Posted on Apr 11, 2008
SOURCE: Samsung SyncMaster 740N - backlight dead
Power on monitor is on but faint back light
Posted on Feb 22, 2009
  • 1684 Answers
SOURCE: Samsung 226BW 22" LCD wont turn on and flickers a blue light
Hello cstafford35,
Your monitor has a very common problem. The internal power supply has blown a part called a capacitor. If you are comfortable working with electronics and with soldering I can talk you thru the diag/repair. If you are not ready to tackle that we also offer a repair service, about $30 plus shipping for your model. Let me know if you want to try fixing it yourself and we can go from there. The repair will require opening the monitor case and replacing from 2 - 5 parts. You can call me at 318-447-9040 if you have questions.
Buddy
Corporate Computer
Posted on Jun 17, 2009
SOURCE: samsung
I have two of these, both of which were just dead. The back snaps off after the screws are removed and the power supply board is the small one with heat sinks and a number of vertically mounted electrolytic capacitors (cylindrical, maybe 1/2 inch in diameter, dark plastic covering, aluminum showing at the top). Some of the capacitors were bulged at the top which is always a bad sign. I decided to replace all of the capacitors in the area between the two heat sinks (six of them). The total cost from Digi-Key Electronics was under $9.00 including shipping.
820uF 25V (2)
1000uF 10V (2)
330uF 25V
330uF 10V
Get ones rated for 105 degrees centigrade.
Good as new!
Posted on Jun 20, 2009
benwabnick
  • 2404 Answers
SOURCE: samsung syncmaster 226BW no backlight
Look for any bulging capacitors, instead of a flat top they will look "pregnant".
If you see any of those then replace them with capacitors of the same UF rating and the voltage needs to be either the same or higher.
If you dont see any bulging capacitors or burnt parts, then its got be the LCD at that point thats not staying on and the cost to replace the LCD is as much if not more then to just get another monitor.
Posted on Aug 27, 2009
Pink and Green Horizontal lines across screen
Normally, horizontal lines on an LCD or LED monitor indicate a bad control board inside the monitor. However, occasionally the problem can be caused by loose or bad cable connections. The only things that you can really do is to disconnect both ends of the monitor cable and reconnect them firmly. Also, you can disconnect the monitor cable completely and just leave the power cable. With only the power cable attached, you can turn the monitor on and off. The monitor should have a "startup screen" or display a message that says something like "Video Cable Disconnected". If the green and pink lines are still present without your computer connected, then the monitor has gone bad. The good news is that Samsung SyncMaster monitors usually carry a 3 year warranty, whereas most monitors only have a 1 year warranty. You may be able to have the monitor replaced at no cost to you if it's less than 3 years old.
Jul 27, 2013 | Samsung SyncMaster Computers & Internet
I have a samsung syncmaster 943NW which goes on for about 5 seconds and then just goes black. When restarting the screen it does the same again, goes on for about 5 seconds and then black. Is there...
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
Dec 11, 2010 | Samsung 943NW Monitor
I have a SyncMaster 204 T that the back light wont always light
Look for bad caps in the power supply first, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
report back what you see so we can guide you further.
Feb 06, 2010 | Samsung SyncMaster 204T Monitor
Samsung syncmaster 931a... connected to computer
Hi, its unlikely to be the cable. Most likely cause of this is a faulty inverter board. If you are lucky it will only be 1 or 2 blown capacitors which are easily identifiable and replaceable once you have got inside it. it could however, be almost any of the components on the inverter board or even a failed backlight but this will require further testing and a knowledge of LCD monitor workings.
Nov 03, 2009 | Computers & Internet
How 2 change language on samsung syncmaster p2350 monitor
find the menu button on the monitor to get to language.
Aug 16, 2009 | Computers & Internet
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
My samsung NW920 turns off after 1 min
If the blue LED ist blinking the monitor does not receive a video/sync signal. If the blue LED is on continuously and the display comes on for a few seconds and then goes dark or dim the backlight inverter may well be defective. The CCFL of the backlight needs several hundred volts to function.
Jan 11, 2009 | Samsung SyncMaster 920NW Monitor
Computers & Internet Logo
249 people viewed this question
David Payne
David Payne
