Zanussi aquacycle 1400 E90 error - Washing Machines
kjmac
  • 97 Answers
SOURCE: Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
SOURCE: Zanussi
 The drain filter is clogged (E20)
online manual
http://www.serviceforce.co.uk/pdfs/U21039.pdf
Posted on Oct 31, 2008
barkencoa
  • 3463 Answers
SOURCE: lost instructions
Go to ; www.serviceforce.co.uk
Then click on service center locator, and follow the instructions.
You should be able to find the information you require.
Please rate my fixya solution.
Thankyou.
Posted on Jan 31, 2009
kevin000
  • 1847 Answers
SOURCE: hi zanussi fjr 1254 w error code e90 what does
This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts:
Thanks
Posted on Jul 01, 2009
  • 174 Answers
SOURCE: zanussi jetsystem 1400- error e90
e90 is configuation problem reinstating configuration code may fix this(not easy to do) or electronic has lossed communication with display board. can be a bad connection between electronic and front display board. faulty electronic board the most likely.
Posted on Jul 24, 2010
Testimonial: "thanks for a quick answer"
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded ยท E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Need a free download user manual for a zanussi aquacycle 1200
    You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
    http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
    Jun 28, 2011 | Zanussi Washing Machines
    Zanussi jetsystem 1400- error e90
    Jul 23, 2010 | Zanussi FJS1225W Front Load Washer
    E90 fault
    Blue wiring loom that goes to the front control board from the maim control PCB has bad connection on the user interface.Clean PCB terminals and crimp connector to make connections tighter.if this doesn't work could be user interface fault or main PCB fault.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Sep 02, 2009 | Washing Machines
    I need instructions for zanussi aquacycle 1400 XC
    My washing machine dials won't light up and strait but the power is switched on
    Jul 03, 2009 | Zanussi F1245W Front Load Washer
    Lost instructions
    Thankyou.
    Jan 30, 2009 | Zanussi F1245W Front Load Washer
    ZANUSSI ZWD1471S
    an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
    Apr 04, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
    Zanussi aquacycle 1400 fle 1416w started to make an electric arking noise when spinning now. Now it has stopped spinning. Will the motor be dead or will it just be the carbon bushes that need replacing....
    Hiya Cheap6... more than likely the brushes.. which are easily checked to see if they are worn down.. otherwise its a new or RE-con motor.
    Regards Faggly
    Mar 21, 2008 | Washing Machines
    Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
    i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
    Mar 20, 2007 | Zanussi F1245W Front Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
