Question about Locks & Locksmithing
IQIP ELECTRONIC SAFE code reset
How to reset the passcode
4 Suggested Answers
SOURCE: How do i reset the entry code?
i want to change code to safe
Posted on Feb 03, 2010
SOURCE: gordon electronic safe and can't open it
Wow , I have the same safe thats been locked for more than a year.
I locked the keys in the safe and forgot the code.
I took the thing out side and droped it on its corner and whala.
go figure it worked ,thank you to who ever was the first 1 to try that
cody in west palm beach,fl
Posted on Apr 25, 2010
pctech1
  • 1940 Answers
SOURCE: kingavon electronic safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
Posted on Feb 21, 2011
How do I change the combination on I have a paragon digital lock & safe
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
NOTE:
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
My sister locked herself out of her Justice digital safe and it is on voice mode, every time we try to reset the passcode it does not work. Does this mean that the safe is broken?
The safe would need to be open to change the passcode. Also there may be a time delay after several incorrect attempts to open. I am not at all familiar with this brand.
Jul 21, 2014 | Safe International Digital Electronic Safe...
We don't remember the code please help with the axample
You must be having the manual override keys. Just open the safe with those keys and reset the passcode.
Jul 14, 2014 | Safe International Digital Electronic Safe...
Cannot open my secret safe by justice
Reference: Paisley Electronic Push Code Safe
Item # 5661462
Purchased at Justice. May be one of the following design/colors: 1. Pink and black 2. neon green 3. tye-dye (all in zebra pattern, I believe)
To gain access to safe without code proceed with the following simple instructions:
Use a screw driver to access batteries on the bottom of the safe. Remove all three AA batteries.
WAIT AT LEAST TEN SECONDS before reinserting betteries to functional position. Replace screw. Key in default passcode "0000#" Safe will now be unlocked and upon opening you can reset passcode. Hold down the "*" and when voice prompted to "key in passcode" enter new 4 digit code followed by the # sign... HOLD "*" until completed code with "#" You will hear the voice command, "enter passcode" after each digit entered. [Press & hold "*" (1234) press "#" release "*"] Close safe and new passcode should be set and work properly. If not, enter default "0000#" and try to reset once again.
Feb 03, 2014 | Toys
Micromark Electronic safe
Contact the manufacturer with the model and serial numbers. They CAN supply a default passcode number.
Jul 24, 2009 | Safe International Digital Electronic Safe...
Need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Apr 06, 2009 | Safe International Digital Electronic Safe...
Locks & Locksmithing Logo
514 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
