Question about Epson TX100 Series
Print head doesn;t move at all in epson stylus tx100
Repair of epson stylus tx100 print head doesn't move when turned on or even to replace cartridges
    Top Expert:
  • Epson Master
  • 11,573 Answers
Anon, epson stylus tx100 print head doesn't move when turned on.
epson printer problems
Posted on Aug 25, 2016
4 Suggested Answers
  • 1456 Answers
SOURCE: '01 install ink cartridges' displayed on
Hello
first of all,double check all the cartridges have been installed correctly.Press the On button to turn on the Epson Stylus CX, or (if already on) press the Setup button.
Select Maintenance and press OK.
Select Change Ink Cartridge and press OK.
Open the cartridge cover,Press down all the ink cartridges until they click into place to make sure they are properly seated.
Close the ink cartridge cover and press it until it clicks into place.Press OK to begin charging the ink. This takes about 2 minutes.
You see a message on the display screen when ink charging is finished
PLEASE NOTE; With the Epson Stylus CX series printers, when you change one ink cartridge, all of the ink cartridges need to be replaced with new ones.
For whatever reason, Epson has it setup so the printer will only operate with each ink cartridge starting at the same amount.So when one cartridge is replaced, all of the cartridges need to be replaced.
Posted on May 01, 2011
vijaivee
  • 120 Answers
SOURCE: Error for my Epson TX100 printer " parts has
Part unavilable. Please replace the printer
Posted on May 25, 2011
  • 14 Answers
SOURCE: BLACK INK NOT PRINTING
Hi Hmmg,
This is a clear indication that some thing is gone wrong in your printer's circuit. Please get it checked by an authorized service engineer.
Regards.
Nat
Posted on Jun 29, 2012
Epson tx100 copier problem
try cleaning the head using the cleaning procedure of the printer canon ink cartridges
Nov 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How to change cartridges epson stylus sx 400
From older Epsons: If the ink cartridges are empty (red light on), hold the ink switch 3 seconds to move the print head to the left. If they are not empty, hold paper switch until print head moves left. Once you remove a cartridge you can't reuse it, even if there's ink in it according to Epson.
Nov 16, 2009 | Epson Stylus C86 InkJet Printer
Epson Tx100 does not recognize my ink!
there is a chip re-setter located just above the cartridges. it is actually a small button switch. if that does not work, try to remove the cartridges. just lift them (1 by 1) slightly then put it back again
Aug 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
How do I get the ink cartridge to stop in front of me so I can replace it on my Epson TX100
Turn on printer, and unplug power when carriage moving. Then carriage can move by hand freely.
Jun 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Installing Ink Cartridges
I have a similar problem. I can get the print head into the appropriate position by using the ink cartridge replacement utility in the maintenance tab of the printer properties dialog.
Oct 05, 2008 | Office Equipment & Supplies
Catridge won't go to right position
Please follow the steps below to replace one or more cartridges.
NOTE: It is necessary to have all four ink cartridges installed and supplied with ink in order for the unit to function properly. The unit will be in an OFFLINE state if the any of the cartridges are expended. This is a protection feature of the unit, to prevent air from being pumped through the print head.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
**NOTE** To avoid damaging the unit, NEVER move the print head by hand.
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the
CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
Jun 12, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson c43sx does not print
It is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
Replace the cartridges with genuine Epson ones and try again. The genuine ink will also help to clear any hardening cheap ink in the print head.
Apr 02, 2008 | Epson Stylus C43SX InkJet Printer
change the cartridge thats simple red light indicating you must change your catridge
Computers & Internet Logo
116 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
