Question about Sharp Plasmacluster Air Purifier With Humidifying Function White
C2 sign blinks and product stops working - Sharp Plasmacluster Air Purifier With Humidifying Function White
Exclamation sign blinking
More information is needed such as make and model to solve your problem. Start by checking to be sure there is no water in it.
Mar 15, 2014 | Dehumidifiers
Red exclamation sign blinking
Dehumidifier? Sounds like a warning of some sort. A humidifier does a simple job, removing moisture from the air. If yours is not set up to drain, it could have a full holding tank. Empty it out and give it a rinse and it should be good. Drop a couple drops of chlorine bleach in it to keep down the mold growth.
If it isn't a full tank, it could be an air filter that needs cleaning or replacing. Often these things are programmed in and needs to be cleared. Clean and or replace any and all air filters and look for a reset button.
Good luck.
It stopped working. One display reads "CH" and
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Mar 26, 2011 | Comfort-Aire BHD-501 Dehumidifier
3 yr old Gold star / LG dehumidifier stopped working
Here is a tip that I wrote to help people with just that dehumidifier problem..
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Apr 30, 2010 | Dehumidifiers
Does not collect water (also 2 years old).
the evaporater coils rot out and the freon leaks out. thats about all the longer these newer ones last now.
Jul 09, 2009 | LG LHD45EL Dehumidifier
Won't Power On
This reply does not solve the problem, however my MAYTAG M7DH
45B2A DEHUMIDIFIER had the same problem.
Circuit Board COR 268BV1.O had circuits burned (on lower side of
board). The circuits that showed signs of arching were the right end
of D1, D 2, D3, D4, and at C2, C3, C4, C5, J1, O1,.
Apparently water must have entered the area and shorted these circuits. But I do not know. The only alternative is to replace circuit
board or junk it
MY LAB
Mar 25, 2007 | Maytag M7DH45B2A Dehumidifier
Blinking bucket full light and humidity setting stuck at '01%'
yes but i might be late. if you still have this let me know
Jan 09, 2007 | Kenmore 54501 Dehumidifier
Sharp Plasmacluster Air Purifier With Humidifying Function White Logo
Top Sharp Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Sharp Dehumidifier Expert? Answer questions, earn points and help others
