Question about Dehumidifiers
Philco Dehumidifier shows F2 in the display and no button can be pressed to clear the F2. What is the meaning of F2 and can i solve it by myself?
2 Suggested Answers
reddyanantha
  • 205 Answers
SOURCE: F2 ON THE DISPLAY / WILL NOT RUN / MODEL FDB30R1
hello sir/mam
this is because of the error in the programme so please switch OFF for 1 mint and switch ON then see the display.
Posted on Oct 08, 2009
I have a Blyss WDH316DC dehumidifier with E3 in display. What does this mean?
What E3 Means? This is simply an error code with your dehumidifier please.
It s not clear whether you can attempt to reset your unit or fix it on yoir own. So sorry about this.
It appears yoir unit requires repair by a qualified dehumidifier service technician.
You can exploit the warranty if this is still valid. Simply return to point of purchase with your original receipt
Nov 13, 2017 | Dehumidifiers
I have a Frigidaire LAD504TDL dehumidifier and code 'ES' shows on display. What does this code mean? Unit runs but not much water in tank.
Good Morning Mark, thank you for your post!
I see that your Frigidaire dehumidifier is displaying an error code of "ES" and you would like to the meaning of that error code. The "ES" error code stands for evaporator thermistor error. This could be a possible problem with your control panel, thermistor, or a wiring harness. I would recommend contacting your manufacturer for further assistance with your dehumidifier. Best of luck! -Matt
Jun 08, 2015 | Frigidaire Dehumidifiers
The F2 code is on in the humidity window of my Frigidaire dehumidifier? Not in manual. What does this mean?
Good Morning friend, thank you for your inquiry!
I see that you are having trouble with your Frigidaire dehumidifier displaying an error code of "F2". Typically, an "F2" error code stands for a miscommunication error. This could be a possible problem with a sensor or control panel. I would suggest performing a reset and that can be completed by disconnecting the power from your dehumidifier for roughly ten minutes. If you are still under warranty I would recommend contacting your manufacturer to see if any additional assistance can be provided. Hopefully this is helpful. -Matt
Feb 13, 2015 | Frigidaire Dehumidifiers
My dehumidifier does not work. And the display shows F2
Try to get a manual on this site, maybe it will help :) http://bit.ly/19XA66M
Aug 12, 2013 | Dehumidifiers
Frigidaire dehumidifier has a F2 error and will not operate
Hello - Typically error code F2 indicates a sensor failed has occurred on the dehumidifier. You may want to contact your manufacturer to verify if the part is available and can be replace. Some do, some don't. Also confirm if the unit has a limited warranty on such concern.
Oct 20, 2012 | Whirlpool Dehumidifiers
I just purchaed a DE Series Dehumidifier. The instructions say to press the arrows keys to adjust the humidistat, but whenever I push the arrows the display reads "on". So I don't know what...
It is not abnormal for ON to show up when you first push the arrow up or arrow down button. If you want to lower the humidity press the arrow down button again, once the ON lights up. The lower you take the percentage the more humidity will be removed.
Hope this helps you and thanks for choosing FixYa.
Aug 22, 2011 | Haier HDN655E Dehumidifier
Haier dehumidifier model de45ej-t What does code e2 mean? Unit does not run.
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
Jan 09, 2011 | Haier DE45EAL Dehumidifier
Programming timer
SETTING THE MACHINE TO TURN ON
1. Make sure the dehumidifier is plugged in but turned off.
2. Press the button with the clock symbol below it.
3. Press the up arrow to set how many hours until you want the machine to turn ON. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
4. After you have stopped pressing the arrow buttons the display will return to the original display showing temperature and relative humidity.
5. After the above steps are completed the dehumidifier will turn ON in the number of hours that you have set (programmed).
SETTING THE MACHINE TO TURN OFF
1. Make sure the dehumidifier is plugged in and running. You should hear the fan blowing for sure.
3. Press the up arrow to set how many hours until you want the machine to turn OFF. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
5. After the above steps are completed the dehumidifier will turn OFF in the number of hours that you have set (programmed).
Jun 21, 2010 | Danby DDR5009REE Dehumidifier
hello sir/mam
Oct 08, 2009 | Dehumidifiers
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
