Bluesky BLF 1060x
I have a washing machine model Bluesky BLF 1060X in my flat, and need a user manual in English, I tried randomn washing programmes which ran for 3-4 hours and the washing still ended up soaking wet, so a waste of energy as I could not understand the programmes I was setting it for as they were in Spanish. It is NOT made by Beko or Hotpoint as I have looked on their web pages and there is nothing relating to this model, so the information posted here is wrong! Why am I finding it so difficult to find a user manual for this make and model? Please help
  • 1294 Answers
SOURCE: beko wma 510 washing machien leaving clothes un rinsed and wet.
Find out where your filter is & clean it out thoroughly, refit.
Posted on May 10, 2008
  • 353 Answers
SOURCE: Looking for a User Manual in English for 2 Balay
Posted on Aug 11, 2010
  • 15935 Answers
SOURCE: I've bought a Bluesky BLF1009/1 washing machine in
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
  • 15935 Answers
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn't cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
  • 1031 Answers
SOURCE: beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
Posted on May 22, 2012
Can you tell the best program for a mixed clothes wash on a bluesky blf 1011
Sorry there is NO BEST just do a normal wash .depending on how dirty the stuff is of course . fixya can not determine what your stuff looks like
Sep 26, 2017 | Washing Machines
Please see the question below. Will the RQ12 head work?
Yes, the RQ12 type heads will work on Arcitec model 1060X. However, your original cap will not fir the RQ12 heads. If you have a cleaning machine, using the RQ12 heads will make it incompatible with the cleaning machine also
Jul 30, 2014 | Philips arcitec 1060 Electric Shaver
Bluesky BLF 1060X user manual
can you take a picture
front ,side and the back plus may be the filter
Feb 08, 2014 | Washing Machines
I installed windows 8 on my inspironmini 10 but to run apps it says resolution low. My resolution is 1060x 600 i guess.. Which is maximum..
Increase resolution, Did you check the specs of your machine against the min. required specs of Win 8?
Dec 04, 2012 | Computers & Internet
Manual de Bluesky BLF 518
Not a solution but a follow on question?
How do I remove the door hinge.
It has broken in 2 parts. The part attached to the door I can remove. The part attached to the actual Washing Machine, I have removed the 2 obvious screws from the outside , but it will not come away.
Looking inside I cannot clearly see any screws thru from behind!,
But its not easy to see !
Any Advice tips/hints etc Greatly Appreciated
Aug 18, 2012 | Washing Machines
The red light showing the shaving head remains on and the shaver discharged the shaver is one year old
Philips suggests changing the heads every 12 months. The indicator is instructing you that it is time to change them. You will find replacements for model 1060x at See link below
Dec 01, 2010 | Philips Arcitec 1060X
I need a user manual for the Norelco arcitec 1060x electric shaver.
You can get the manual on the link below.
Good Luck and please rate 4 thumbs up for the free answer
Sep 30, 2010 | Philips Arcitec 1060X
I've bought a Bluesky BLF1009/1 washing machine in Spain and can't find an English language User Guide.
Jun 15, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
