Question about Ovens
Concorde turbo hygena double oven
My concorde turbo by hygena oven is located inside housing at eye level. have I got to remove it from the housing to get to the element?
aborcass
  • 2651 Answers
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Posted on Dec 21, 2008
barkencoa
  • 3463 Answers
SOURCE: Changing an element on the main oven - Neff U1721 Double oven
You should not need to remove fan to access the element fixing scew(s).
You may need what is called a torx screwdriver, if the screws are conventional screws, but some times a small screwdriver will undo them if they are not too tight.
let me know if you require any more assistance.
Plz rate my solution.
Thanks.
Posted on Jan 10, 2009
barkencoa
  • 3463 Answers
SOURCE: Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Thanks.
Posted on Jan 12, 2009
  • 291 Answers
SOURCE: Oven doesn't reach temperature setting
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
Posted on Aug 31, 2009
  • 417 Answers
SOURCE: Replacement knob for Hygena Turbo electric oven
You should be able to get a replacement fairly readily, try www.appliance-parts.co.uk or www.cooker-parts.co.uk.
Posted on Jan 04, 2010
Diplomat elite double oven. No manual.how do I set the clock.
Hello -
Apparently, the Diplomat brand of ovens ended production in 2008.
Prior to the end of production, Diplomat was part of the MFI company, with the company's Hygena brand name combined with Diplomat.
I have not yet found a user manual for Diplomat Elite Double oven online.
However, I have found a Hygena Diplomat manual online (free) and the manual has instructions for the clock. The instructions MAY be the same for your oven (I hope.)
See:
https://productmanuals.inbro.net/seeinsidebrochure/Product-Manuals_Hygena-Diplomat-Select-Ovens/Hygena-Diplomat-Select-Ovens/page_1
The clock instructions are on Page 10: Using Your Electronic Minute Minder.
Best wishes.
Apr 07, 2018 | Ovens
I have an hygena classic built in oven. The turbo cooking option heats up slightly and the fan works but doesn't get to temperature. The grill and convection oven work fine. Any ideas. The oven is about...
The problem is usually down to the thermostat - sometimes it can be moved and end up touching the grill and burning out - other than that they just wear out after time with the heat.
Have a look here for a spare - its easy to replace if your husband is half competent with fixing things.http://www.espares.co.uk
May 11, 2014 | Ovens
Hygena ahy3120 manual
i need a manual for deluxe hygena oven cooker
Feb 20, 2013 | Ovens
How do you fit a new clock assembly board to a Stove 720EF?
I haven't done it, but I would imagine you would have to remove the entire oven from its housing to take the top off and then remove the front glass front control panel. ( The glass panel can be removed without taking the oven out).
The buttons on this panel are all push on/off. There are two screws located on the lower edge of the panel at either end of the panel. They point upwards. Once these screws are removed, the panel will be loose, but held in place with (3) lugs on the inside of the upper edge of the panel. Basically you have to jiggle the panel around, moving the lower edge out to overcome the lugs. Once the panel is off you will see the inner workings of the oven.
Nov 02, 2010 | Stoves 720EF Electric Double Oven
How do I remove the double oven?
I assume you want to remove it from the housing.
Ensure the power is off to the oven.
Remove 4 screws securing oven to front edge of housing.
With some assistance, slide the oven forward, and bodily lift it clear of the housing.
Make sure there is enough slack in the cable to lift it clear, if not. you will have support it on something whilst doing repair or whatever it is you intend to do.
Oct 26, 2010 | Hotpoint DY46 Style Line Stainless Steel...
Element not working on a hygena oven model no AHY3420. How do I replace it
The element is located at the rear of the oven compartment behind removeable cover.
Remove cover, and disconnect the element, ease it forward, and fit replacement.
Jan 19, 2010 | Ovens
Jan 04, 2010 | Ovens
Thernostat Probe in Hygena QA Built in Oven is hanging down inside. Where should it be affixed?
inside the cooker at the top, they should be two little clips where the probe fits in to
Sep 21, 2009 | Ovens
What connection do you require for eye level electric double oven
You need a 45amp circuit for this double oven, under no circumstances , try to run it off a 13 amp circuit.
Thankyou.
Jan 25, 2009 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
16 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
