Question about Coby Audio Players & Recorders
Restart Play On MP3/Cd Audiobooks
Whilst playing a CD/MP3 Audio disc due to the length of play I have to stop and restart the disc and would like to be able to restart at the point where I was last listening, instead of having to scroll from the beginning each time, is this possible and how is done? play, I would like to be able to restart play at the point where I was last listening without having to scroll from the beginning each time
SOURCE: cd won't play
Easy fix, look at the front of your CD player, you should see a little pin hole, insert a paper clip into it and the pop the CD tray open.
Posted on Nov 28, 2006
how to rectify boot failure pmp-120
Posted on Jan 03, 2008
  • 4402 Answers
SOURCE: ipod nano won't sync mp3 audiobook
Get a new cable if everything else works that is your problem
Usually, unplugging, replugging it and then rebooting solves the problem.
your other options are a driver issue..either with the ipod drivers, itunes, or the USB drivers for your computer itself. since your ipod video and psp work fine, you can rule out USB drivers, but that doesn't rule out additional driver problems.
the other option is there's some kind of failure with your ipod..and sometimes if a device starts drawing power before doing any kind of communication with the computer (like when my rockbox-hacked ipod goes into charge only mode) then windows will assume there's a hardwire issue. the best way to determine if it's an issue with your ipods are take them to another computer and see if they work. if they work fine...try uninstalling and reinstalling itunes (back up your music and database) and see if that solves the problem. if none of that solves it and you know the ipod shuffles are good..then your system has suffered from the mysterious driver failure that's plagued a lot of systems. and generally the only real solution is to reinstall windows from scratch.
Posted on Feb 04, 2008
  • 1175 Answers
SOURCE: yamaha cdc 555 5 disc cd player
If you trust yourself enough to open the case w/o breaking stuff, then open it up UNPLUGGED, locate the laser lens (small,clear,plastic) gently clean the lens with a swab of lens cleaner for glasses.
Also clean the chrome runners that the laser assembly tracks on.
Posted on Jun 26, 2008
  • 149 Answers
SOURCE: My DVD drive can read a CD-ROM and play an audio CD, but it cannot play a DVD
Have you tried more than 1 dvd.
Posted on Jul 17, 2008
What dsks does the CD player play. Does it play MP3 disks?
mp3 is actually a file format that made larger audio files take up less data space. If you have mp3 audio files on a compact disc(CD) it may play it if the player is designed to recognize the format. This was a much bigger issue years ago. Only way to tell is check the manufacturers specifications or simply try it. Good luck.
Apr 25, 2014 | Thomson RK300CDU CD/MP3/Radio/Cassette...
Playerdoes not seem to restart or resune at the same spot that it was stopped in aN AUDIO BOOK.
You can resume play after navigating away from audiobooks. Play resume function is provided in this model. However, if you are unable to use this feature, I'd suggest that you uninstall audible manager and then install again. If the problem persists you can contact Audible support or Philips support.
Hope this helps.
Mar 02, 2011 | Philips GoGear Ariaz MP3 Player
American Audio Velocity CD Players Won't Play Discs
are your cd-r data or audio..(maybe AAV cant play the data disk) make sure its audio can also try wiping the disk with a dry paper towel in a circular motion only (one way)...get any fingerprints /oils off the disk...
Jun 28, 2010 | American Audio Velocity MP3
Why does Burn't Audio CD not play on some CD Players
because the codec's are different, if you have ever burned a avi file and it didnt play till you added say divx ir xivd to get it to play tech leaves out alot of the codec's so there system will work on most but not all cd's dvd's the only way around it is to find out which codec will work for that player to test what I have just told you take the cd to the store and try it on a different mechine and see if it works
Jan 14, 2010 | Teac AD-600 3-Disc CD Changer
What video formats are playable on the Phillips DVP 3120?
DVP3120 can play all DVD, VCD,MP3 and Audio CD and Support the below formats
Audio Video format NTSC & PAL
DVP3120 will play CD, CD-R/CD-RW, Video CD/SVCD, DVD, DVD-R/-RW, DVD+R/+RW, DVD-Video Discs as well as MP3-CD, MP3-DVD, WMA-CD discs and MP3, WMA and JPEG Files.
Let me know if this helps
Nov 27, 2009 | Televison & Video
Rover 25 CD player wont play MP3 format discs
It sounds like your Rover dosn't have MP3 capabilities. You will have to use standard audio CD format (not data/MP3 format). You will only be able to burn about 15-20 songs but they will play in any cd player.
Aug 07, 2009 | Car Audio & Video
DVD player repairing
Double-check your DVD player's user manual/spec sheet to see if it plays Mp3 format files at all. Find out, specifically what kind it can read.
If your Mp3 disc is a DATA CD instead of an AUDIO CD, then nothing besides a computer is going to play it.
Sep 05, 2008 | Philips Magnavox DVD/VCR Dual Player
Insignia NS B2110 boombox CD not playing
Try an audio CD which has been purchased. I think you have MP3's on your cd and your boombox maybe does not support MP3
Mar 07, 2008 | Insignia Sport lDM9700-2 Personal CD...
Mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Oct 02, 2007 | Philips DVD 622 DVD Player
Wont play full length
The Ilo can only play 30 seconds of video per clip. I'm afraid the only real workaround is to trim the video down to 30 second segments and number them in sequence so that the videos play relatively seamlessly. Thankfully, Ilo had the foresight to include a CD-rom with video editing software on it to allow you to do this, but any video editing program that can manage AVI formats will work.
Dec 27, 2006 | iLO XM-MP3-CD Car Stereo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
