Question about Dehumidifiers
F2 is displayed at philco dehumidifiers (PD24GE)
When i turn on the power, it is found that F2 is shown in the display and I cannot press other buttons. What is the meaning of F2?
4 Suggested Answers
reddyanantha
  • 205 Answers
SOURCE: F2 ON THE DISPLAY / WILL NOT RUN / MODEL FDB30R1
hello sir/mam
this is because of the error in the programme so please switch OFF for 1 mint and switch ON then see the display.
Posted on Oct 08, 2009
SOURCE: Haier dehumidifier Model DE45EK-T--just bought.
It takes a couple if tries. Have to press it twice to get down low and have to have at high or low speed.
Posted on Jul 05, 2011
  • 4736 Answers
SOURCE: Recently purchased a Philco dehumidifier, model
Astro9boy, when I first read your post, I considered the problem was was just operator error. But, when I read the Owners Manual for your unit, I changed my mind. It seems there may be a problem with the control panel. But, attempting to reset it may solve the problem.
Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes.
After the time has elapsed, plug the unit in and turn the Master ON/OFF Switch ON
Hopefully, during that 15 minute timeout, the unit reset itself & reverted back to the original factory settings. If so, you can set the controls where you desire.
In case you have misplaced your Owner's Manual, I have included a link to it that you can download and print for future reference. http://www.gilman-group.com/gilman_product_usermanuals/PD24GE_eng.pdf
If the above does not sole the problem, you will need to contact Philco, or the p;ace of purchase, as the unit is still under warranty.
I hope this helped you troubleshoot & solve the problem.
Posted on Jul 13, 2011
Why wont it turn on?
if power is applied then display should show current room humidity , if set is pressed then display should show current set point for desired room humidity , this has to be less than first display otherwise the control will think room has acheeved desired setpoint and shut off , the one of these i had seemd to have an overly sensative collection bucket full sensor and had to be "just right" for unit to run
Feb 17, 2015 | Haier 45-Pint Dehumidifier
The F2 code is on in the humidity window of my Frigidaire dehumidifier? Not in manual. What does this mean?
Good Morning friend, thank you for your inquiry!
I see that you are having trouble with your Frigidaire dehumidifier displaying an error code of "F2". Typically, an "F2" error code stands for a miscommunication error. This could be a possible problem with a sensor or control panel. I would suggest performing a reset and that can be completed by disconnecting the power from your dehumidifier for roughly ten minutes. If you are still under warranty I would recommend contacting your manufacturer to see if any additional assistance can be provided. Hopefully this is helpful. -Matt
Feb 13, 2015 | Frigidaire Dehumidifiers
Recently purchased a Philco dehumidifier, model PD24GE. It turns on perfectly well but the humidity reading always says 20%, even if I put it outside where I know the humidity is at least 80%. Any...
Jul 13, 2011 | Dehumidifiers
Haier dehumidifier Model DE45EK-T--just bought. Displays E2. Power button not working--had to unplug to turn off.
Jun 05, 2011 | Haier 45-Pint Dehumidifier
How to fix f2 message? what is wrong?
If the display reads "F1" or "F2", a sensor has failed. Contact your Authorized Frigidaire Service Center.
Feb 21, 2011 | Frigidaire FDF50S Dehumidifier
When the mode button is pushed, I only receive the option of dehumidifying, or just fan. The manual claims it has a heat option but it is not available. A friend of mine has the same one and they have the...
Sorry to read about your problem, I hope this helps you out.
Their has to be a model difference issue . I have checked the Manuel and have put a copy of the section, for modes. and their is no heat only mode.
Your unit uses heat anyway, so i really do not know how, heat only would help you. I would say to look at the sticker on your friends model, and see if the numbers are exact.
Default Setting:
When the unit is first connected to a power supply, the electronic circuit board will automatically default to the following factory settings;
Mode: Dehumidifier Humidity Set Air Value:60% RH Fan Speed: = Low
NOTE: In the event of a power failure or the unit is switched 'Off', the most recent settings are retained and restored once the power is switched "On"/resumed.
IMPORTANT NOTE: Depending on the ambient humidity conditions, when power is restored or switched 'On' the dehumidifier may not start automatically under the factory or custom (see page 7) default setting. This is an indica- tion that the ambient RH% level of the surrounding envi- ronment is lower than the current default setting and it may be necessary to select a lower set RH% value.
DRY MODE SELECTION: 1. The unit does not have to be switched on (opera- tional) to select/set a program. All programs can be selected with the unit in the "off" position.
2. Press the MODE button until the Dry symbol is shown in the mode area of the display. Note: Each time the MODE button is pressed, the setting will alternate between DRY (dehumidifier) and FAN (only) mode.
3. Press the or cursor buttons to select the desired RH% operating value. To select CONTINUOUS operation,pressthe buttonuntilthesymbol"--" appears in the SET AIR display. During CONTINUOUS mode operation, the humidistat (control) will be by-passed and the compressor will operate non-stop regardless of humidity conditions.
FAN SPEED SELECTION:
4. Press the fan symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options. The fan speed you select will appear in the LED display; either a 4 blade fan symbol for 'high fan' or a 3 blade fan symbol for 'low fan' will be shown in the display area.
5. When all settings are complete, press the I/O button to start the selected operation (MODE) and the blue opera- tion light will illuminate.
FAN ONLY MODE SELECTION:
1. Press the MODE button until the fan blade symbol is shown in the mode area of the display. 2. Press the "Fan" symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options.
3. When all settings are complete, press the on/off button to start fan mode operation and the blue operation light will illuminate.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Danby DDR586R Dehumidifier
I have an LG LHD65EBL dehumidifier. When I checked on it today the unit was not running and the display read "CH 01". I tried cleaning the filter, cleaning the front of the coils, and resetting the unit by...
Hi
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Take care.
Aug 15, 2010 | LG LHD65EBL Dehumidifier
Programming timer
SETTING THE MACHINE TO TURN ON
1. Make sure the dehumidifier is plugged in but turned off.
2. Press the button with the clock symbol below it.
3. Press the up arrow to set how many hours until you want the machine to turn ON. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
4. After you have stopped pressing the arrow buttons the display will return to the original display showing temperature and relative humidity.
5. After the above steps are completed the dehumidifier will turn ON in the number of hours that you have set (programmed).
SETTING THE MACHINE TO TURN OFF
1. Make sure the dehumidifier is plugged in and running. You should hear the fan blowing for sure.
3. Press the up arrow to set how many hours until you want the machine to turn OFF. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
5. After the above steps are completed the dehumidifier will turn OFF in the number of hours that you have set (programmed).
Jun 21, 2010 | Danby DDR5009REE Dehumidifier
hello sir/mam
Oct 08, 2009 | Dehumidifiers
Dehumidifiers Logo
106 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
