Question about Avanti 18CYW Compact Refrigerator
Where are the coils located on Avanti 308ywt compact frog
3 Suggested Answers
  • 87 Answers
SOURCE: avanti issues
Take this unit back even if you bought it used and get a new one it is still under warranty.
Posted on Oct 07, 2008
samrat_babui
  • 296 Answers
SOURCE: My avanit 308YWT compact refrig isn't cooling on
hi
it seems there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dyer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns.
hope this will solve the prob
if u ve further queary plzz do inform us.
all the best
regrds
Posted on Jul 22, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Nataly if there is not any cold air anywhere and compressor is running that indicates a Freon leak and worth very little due to repair cost. You must be sure that compressor is running not the fan noise
Appliance 911 Sea Breeze
Nov 12, 2015 | Avanti Refrigerators
Freezer gets cold bottom fridge wont
Food compartment fan may have failed or freezer chocked with ice blocking air flow to fc.
Nov 23, 2013 | Avanti 308YWT Compact Refrigerator
I have a compact avanti regrigerator. It doesnt get cold anymore. What do you think might be the problem? I bought it since 2007.
There are three possible reasons for this;
\the thermostat needs replacing
\The refrigerant has leaked out
\ the compressor has failed
Either way you will need a technician to look at this as it involves an electrical diagnosis
Apr 05, 2011 | Avanti 308YWT Compact Refrigerator
For the temperature, to make it colder to we turn the knob towards the higher numbers or lower?
Normally the lower number is more cooling and hence the setting is ideal to be kept at mid point.
In twin door adjustment witth single control lower setting more cooling to freezer and as it goes up the temp of the fridge increases.
So you might need to recheck with this model
Sep 16, 2010 | Avanti 308YWT Compact Refrigerator
It just do not get cold, sounds like it is working, could be temperature control?
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 21, 2010 | Avanti 308YWT Compact Refrigerator
My avanit 308YWT compact refrig isn't cooling on the bottom portion even though the freezer seems to be cooling.
hi
all the best
regrds
Jul 22, 2009 | Avanti 308YWT Compact Refrigerator
Ice maker will not eject ice. Sometimes it works, sometimes not.
These units need to have the evaporator coil cleaned routinely. A cleaning solution can be obtain at a refrigeration outlet. Another common problem is the ice thickness is out of adjustment and the ice gets too thick and will not come loose on the defrost cycle, check the thickness.
Nov 27, 2008 | Avanti Freezer Compact Ice Maker - 12 lbs....
Avanti issues
Oct 07, 2008 | Avanti 18CYW Compact Refrigerator
Avanti 18CYW Compact Refrigerator Logo
12 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
