Question about Nextar Audio Players & Recorders
Ma588f 200s driver
Control volume defect
In my Amp when I increase the volume - the Amp will deliver full volume before it reaches the point 2 to 3 and above that it delivers very light increment of volume increase but with much no-clarity music....
This sounds more like the volume control is defective. Please update this with the make and model so more details can be provided. Different models use different techniques for volume control and the described behavior will can be caused by many types of defects depending upon the circuit.
Thanks,
Dan
Sep 20, 2010 | Audio Players & Recorders
Sound is not working
There are some possible reasons why the sound is not working. It could be the volume control is in "MUTE", or the right sound card is not selected in the volume properties, or the speaker is defective.
Here's what you need to do:
1. Try to connect an external 2-channeled PC speaker. The computer should recognize the speaker and the sound should be transferred to the PC speaker. If the sound works on the PC external speaker, then you know that the volume control is NOT in mute and the sound card is selected. It means also that the built-in speakers could be defective.
2. If the same problem occur after connecting an external PC speaker, check the volume control, and make sure that the "MUTE" box is not checked. Then adjust the master volume.
* If everything's properly configured, but there's still no sound, check the volume properties under the Control Panel. Be sure that the correct sound card driver is selected. If that did not help, try to re-install the sound card driver.
* And the last option, contact the manufacturer and have them fix it for you.
Thank you and good luck!
Jun 26, 2010 | Acer Aspire 5535-5050 Notebook
DEFECTIVE MANUAL VOLUME CONTROL ON SONY CMT-HPX10W
remove knob and use some pressurised air to blow out any scum thats built up. yes a remot would still work.
Jun 02, 2009 | Sony CMT-HPX10W CD Shelf System
Instructions required for Olympus WS-200S voice recorder
http://olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1322
Here is the link to the Olympus website where you can download a copy of the user manual
May 18, 2009 | Olympus WS-200S
97 Jeep Grand Cherokee Limited Stereo problem
If you still have audio but unable to turn the volume, there are 02 possible problem:
- the volume control is defected will not respond ( electronic volume control; need logic low/high to activate the audio )
- the front control PCB is broken ( can be fixed if there is a small cracked )
If no audio at all then most likely audio output IC defected
Dec 19, 2007 | Cherokee (REF) AM/FM Stereo with CD Player...
Philips magnavox tv volume control
if your are using a remote control,your volume button is shorted,and of you are using your manual control,your tact switch in volume is defective try to replaced  another one.
Oct 18, 2007 | Philips Magnavox PR1906C 19" TV
22 people viewed this question
Top Nextar Audio Players & Recorders Experts
lolthepcman
ray gallant
Paul Chapman
Paul Chapman
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
