Question about Invicta Grand Diver Pro Automatic 3045 Watch for Men
Can't set time
I can't pull the cron out, it only screws. am i doeing something wrong or is something wrong?
I wanted to know how to set the date pulled and turn the button it is not working wanted to know if I was doing something wrong
To set the date you pull the button out half way. To set the time you pull it out all the way.
Feb 09, 2015 | Watches
How to set ladies rolex watch?
A standard ladies rolex should have just one stem and crown on the side. Occasionally the crown is a screw down crown. Try to pull the crown out if it does not pull out try to pull and unscrew it at the same time. There are two settings one you pull the stem all the way out and that should set the time, if there is a day or date setting, you push the stem halfway in turn one way for day and other way for date. Please let me know if there are any other buttons on watch thank you!
Aug 27, 2011 | Watches
I can't set the time on my new watch! Help please?
what kind is your watch?
does it has a crown ?
screw crown? if yes, turn the crown loosen counter clockwise.
pull gently day and date adjust
pull gently again time set
Dec 14, 2010 | Watches
How do you pull the crown out on and invicta watch
mcdevito75 here, Your invicta may have a screw down crown that adds water proof protection to your watch, try to un-=screw the crown when un- screwed then pull up to set time.
Jun 26, 2010 | Invicta Subaqua Noma Iii S
I cant set the time.
does it have screw down crown if so you need to unscrew it anti clockwise once you do this you can set time etc if it does have screw down crown remember to scew it back its spring loaded so you need a little pressure if you dont it wont be water resistant..
Mar 26, 2010 | Tag Heuer WK1120.BB0314 Wristwatch
The winding stem came out when i was trying to set time formula 1
I would advise you to take it to an authorised dealer (see the Tag Heuer web site (www.tagheuer.com) ) and let them sort out why the stem came out. I feel sure that this shouldn't happen and it is likely that a repair is needed.
(It may be that something that restricts the movement of the stem has become detached. If this is so, then something may be moving about inside).
Feb 11, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
I have an Nike Alpha project watch that's around 10 years old but don't know where the manual is. The watch has the following modes: TIME, CRON, DATA, TIMR, CNTR, ALRM I'm trying to find out if I can set...
Not too difficult. Press BL (bottom left) to go to TIMR. Then TR to confirm. Then TL and hold until it "confirms". Then in "Seg 1" press BR to move to minutes. Press TR to adjust to 10 Press TF to accept Press BR to move to Seg 2 Press TL and hold until it confirms. Press BR to move to minutes. Press TR to change to 1 Press TF to confirm. You can set up more segments like this.
Dec 26, 2009 | Nike Watches
How do I change the time on the tissot 1853 touch watch
  1. Locate the screw on the side of the watch face. This screw is what you will use to set the time on your watch. Water-resistant watches have a screw-type crown, and the screw must be turned toward the body (unscrewed) before it can be pulled out for further use. If the watch is not water-resistant, the unscrewing is unnecessary.
  2. 2 Pull the screw gently outward. The screw can be pulled outward in two positions. The first position sets the date and day. Pull the screw out farther (into the second position) to set the time.
  3. 3 Turn the screw either clockwise or counterclockwise to move the minute and hour hands to the desired time. Push the screw all the way in (and turn it away from the body if you have the water-resistant model) when you are finished.
    Digital Watch
  4. 1 Locate the three buttons on the side of the watch face. These are the buttons used to set the time. The top button is the "+" indicator for increasing the numbers. The bottom button is the "-" indicator for decreasing numbers. The center button is to activate the setting mode.
  5. 2 Press the center button in for one second. The watch will beep.
  6. 3 Press the top "+" button for two seconds. After the watch beeps, you can begin setting the time.
  7. 4 Press either the "+" button or the "-" button (depending on whether you want to increase or decrease the numbers) to set the time.
  8. 5 Press the center button when you are finished. The watch will beep. This validates the setting. The seconds will revert to zero.
Read more: How to Change the Time on Tissot Watches ' eHow.com http://www.ehow.com/how_5934972_change-time-tissot-watches.html#ixzz14ifvni46
Nov 04, 2009 | Tissot T-Touch T33159851 Wrist Watch
SKAGEN 521LBLB1 ALARM INSTRUCTIONS
everything you will need is right here.
http://www.skagen.com/service/watchInstructions.fx
p.s. there is another little stem on the lower right side that controls the alarm it must be pulled out.
May 08, 2009 | Skagen Alarm Watch Black Square 521LBLB1
Invicta Grand Diver Pro Automatic 3045 Watch for Men Logo
10 people viewed this question
Top Invicta Watches Experts
Jimmy Accardi
Geoff
Are you an Invicta Watch Expert? Answer questions, earn points and help others
