Question about Garmin aera 500 Color Aviation GPS (Pacific Database)
Aera 500 dies when battery door is closed
The uit is dead. It starts up with the battery door removed. Then prompts me to close battery door. When I do that it dies.
Why won't my key turn the ignition for my 2000 Dodge Stratus. The steering wheel is not locked but neither key will turn in the ignition.
Probably aftermarket alarm. Should be a small switch close to it to turn it off. If it were mine, I would remove the system .
Nov 28, 2015 | 2000 Dodge Stratus
Garmin troubleshooting
perhaps the switch behind the door is defect.
Or just the contacts a bit dirty? Try opening and closing the battery door several times. Make sure you hear the switch click. If it won't help, visit a repair centre.
Jul 23, 2014 | Garmin aera 560
Bosch nexxt 500 series repair manual
Unplug it and take the front panel off under the door. There is a drain plug. Remove it, BE READY FOR WATER!. Clean it out when it is done draining. Reassemble and plug it back in.
Dec 06, 2013 | Washing Machines
Battery Keeps dying, Car thinks doors are still open when closed .
Please check all door close sensors for each door.
Apr 15, 2013 | 2005 Lexus ES330
My steering column is locked and I cannot get the key to turn to start the car. I have a 2008 pontiac g5.
The battery dead? Remove the battery cables and wait and then see if the key will turn. If it will not remove the key ( will it come out?) the key can be the wrong one ( maybe) you can have a blown fuse. Any fuse so you need to check them all. If the key will turn with the battery disconnected then put the car in park and turn the key off and remove it from the car. with the window down and the doors all closed and the hod open reconnect the known good ( charged Battery) with the battery connected don't open the door but reach in and put the key in and start the car. the doors should lock when the engine starts. reach in and unlock the door and get in and close the door. then turn the car off and remove the key get out and close the door and lock it with the key. wait a minute and then unlock the door with the key get in and drive away like normal. do everything though or you'll unset the reset cycle. Make shure that the break lights work as they control the unlocking feature of the collum.
Sep 28, 2010 | 2008 Pontiac G5
I have a 02 silverodo battery went dead i charged battery reinstalled it it starts but dies and with the key out of the ignition security light stays on
you need to disarm the alarm. unplugging batt. or dead battery being jumped sets of the alarm not all alarms make noise
use remote to lockand then unlock doors need to be closed
or lock then unlock door with key if it dont reset then try passenger door
Mar 22, 2010 | 2002 Chevrolet Silverado 1500
Battery died after experancing power door didn't close fully...
if you turn off the switch for the interior lights,an override,it will prevent the battery from going dead until you can get the door alignment or switch repaired.the interior lights,there is more than 5 will kill the battery for sure.
May 23, 2009 | 2003 Chevrolet Venture Passanger
1997 park ave battery dies over night
I just posted my experience in another place on this site but on my 1992 PA the accessories relay stuck closed. This relay is the one that allows you to listen to the radio etc and keep things on until you open the door then all shuts off. When it is stuck closed accessories keep running until your battery drains dead. The relay was replaced and all worked great.
Feb 04, 2009 | 1994 Buick Park Avenue
My battery is dead and my horn keeps honking and wont let it take a jump start how do I get the horn to stop
Try disconnecting the battery for 5 minutes. then when you reconnect the battery lock and unlock the drivers door with the key, door closed. this will on some models deactivate the anti theft system. but it must be done with the hood closed and all the doors closed and from outside with the key. mike
Jan 04, 2009 | 2005 Lincoln Town Car
2000 XJ8,CAR GOES DEAD AFTER NOT BEING STARTED FOR A WK
when the bat is fully charged , open the bonnet and remove one of the bat. post connections. With the key off (like it is when it sits and dies) and the doors and etc. closed , fan off , radio off.... place the cable you took off on the bat post . if there is a spark or anything... report back.
Also , listen for anything under the bonnet when you do this...
Jan 03, 2009 | 1998 Jaguar XK8
Garmin aera 500 Color Aviation GPS (Pacific Database) Logo
20 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
