Question about Weber 6492 Original Instant-Read Thermometer
No readout battery replacement - Weber 6492 Original Instant-Read Thermometer
    New Friend:
You have to twist the top part about 30 degrees and it will pop off.
Posted on Mar 04, 2015
I HAVE A TUNTURI TREADMILL WITH A GAMMA 300 T.I.E. READOUT ON THE HANDLEBAR. THIS READOUT NOW SAYS THE BATTERY IS DYING OUT AND NEEDS TO BE REPLACED. KINDLY GIVE ME DETAILED INSTRUCTIONS AS TO HOW I CAN...
HI,
The is a screw behind readout Read out unit which we can see through a hole. Remove the the screw and detach out the back cover. Remove the battery wire for the socket and dismadle the battery. Buy a new battery with the same specification and install the new battery. Reattach the back cover and put the screw back.
OK
Sep 29, 2011 | Exercise & Fitness
I bought a casio watch (model AMW-320R, I think that is the model number) with both a tradiotnal hour, minute, second hand and digital readout. The digital readout is fine but the second hand on the...
Normally this is the battery... Try the battery before considering to send the watch to Casio for service. Or, if you send it they will fix it and send it back. They are not very expensive for their service.
Jan 26, 2018 | Casio Watches
How do I repair my kettler condor cross trainer
What's wrong, is the readout simply not working? If thats all it's the battery, which is easy to replace but a little harder to find. Just in case it's the battery I'll paste here my solution:
If you look behind the unit, (directly behind the digital readout) you'll see a small rectangular inset, if you look up in that (I used my cell phone light), you'll see a tab that you can pry with a screwdriver gently to release the computer section. Just keep one hand on top, when you pry it you'll feel the unit pop up, then you can lift it out. It takes 2 AA batteries, thankfully not some bizarre disk batteries :)
Btw when you look at the readout, you'll notice it's set in a silver square- that square is the computer module that pops out.
Hope this helps!
Feb 09, 2011 | Exercise & Fitness
I have a kettler condor and have the same battery question as cjb4368. Thanks!
I posted this for a few people, if this is about replacing the battery:
Hope this helps!
Jan 18, 2011 | Kettler Exercise & Fitness
I have a Kettler Elliptical. It is the Condor model. The dash is no longer displaying data. How do I replace the battery? Is there a battery to replace?? Help???
Here's what I posted for someone else, I had to change my batteries this morning:
Hope this helps!
Dec 27, 2010 | Kettler Exercise & Fitness
The unit woorks but there is no digital readout
there is a battery in the display - carefully pull the display out open, the battery compartment and replace with a new battery.
Jul 09, 2010 | EuroCave Performance 59 Undercounter Wine...
When you step on the scale the readout says "LO". Does this mean low battery, and if so I can't find a battery to replace.
Yes it means battery needs replacing. Check oringinal papers that came with scale to see if you need to order special battery. Otherwise go to a battery store that recharges batterys. They usually carry most makes. Take your battery with you so you can match right one.
Dec 10, 2009 | Taylor & Digital Scale Lithium Scale
On my console, all the readouts for the speed,distance...turn on but they come up as all zeros. I put new batteries in but I still get no readouts. Help.
Has anyone had the treadmill apart? Most of the readouts are really very simple. Simply a sensor wire that runs down to the pulley with a sensor at the end. It counts the revolutions of the drive pulley and gives calculated readouts for speed, est calories, distance etc. all the same function really
Check the wire for breaks, check the sensor for positioning and dirt, check the magnet on the drive pulley that tells the sensor pulley position
Oct 22, 2009 | Cadence Weslo 4.6ds Treadmill Walking...
6AE Lo
6AE Lo is probably 'bAt Lo'. Batteries are low and need to be replaced.  It looks like 6AE Lo because of the digital readout (b looks like 6).
http://www.espenergy.com/faq_honeywell_thermostat.htm
Model number shouldn't change what the readout means.
Oct 14, 2009 | Honeywell CT3600 7 Day Electronic...
Readings disappear on thermostat for awhile then come back
Hi Linda,
There are a few things that cause this:
  1. When the heat is starting, it will sometimes go blank for a few minutes and then resume.
  2. Most have batteries, replace them with fresh new ones, if the electricity goes out while you are away, the batteries will keep the settings.
  3. Have someone check the house when it is extremely cold or hire a service to monitor. Your alarm company can usually add temperature sensors to your home, it will add a little safety net for you.
Hope this was helpful, please rate my answer.
Thanks,
Paul
Jan 27, 2009 | Honeywell Programmable Thermostat Heater
Weber 6492 Original Instant-Read Thermometer Logo
823 people viewed this question
Top Weber Home Experts
john h
Tom Chichester
Are you a Weber Home Expert? Answer questions, earn points and help others
