Question about IBM ThinkPad 390X 2626 Notebook
Fix error 0210 stuck key - IBM ThinkPad 390X 2626 Notebook
pkbytes
  • 45 Answers
SOURCE: 'stuck key' on IBM ThinkPad 390E (2626-DOU)
goto the device manager and uninstall the keyboard and restart the system. check that the error is still coming..
If still the error remain same ...shutdown the system and power off and just clap the each and every key of the keyboard to release the keys if any stuck. Check that error by rebooting the system. Hope that the problem is solved.
If still not then maybe the keyboard is going bad.
Cheers - Parveen
Posted on Feb 10, 2008
SOURCE: i have error 0210 stuck key 01 on an IBM
My key R is stuck. And some some letter keys become numbers once I press them
Posted on Jan 28, 2010
  • 111 Answers
SOURCE: error 0210: stuck key 01
I assume its a laptop. laptops some times get stuck keys, meaning one of the keys has not fully released after it was depressed. I recommend getting some compressed air in a can and give it a good cleaning. there might be something stopping git from popping back up. then give the keys a little work out. just mash the keys a bit. then turn it back on. if you still have an error, then you might want to consider replacing the keyboard. if you don't, it will not harm you pc in anyway...good luck
Posted on May 04, 2010
  • 10406 Answers
SOURCE: how to fix an error
One of the keys on the keyboard is "stuck" in the "down" position, so that it keeps sending the same character. Quickly press/release each key, several times, to see if you can "unstuck" that key. Or, replace the keyboard.
Posted on Mar 08, 2011
SOURCE: ERROR 0210: Stuck key 7B,
if this Problem before windows you need to reset keyboard cable anf if the Problem still you need to replace the keyboard
else if the Problem after windows just repair the Windows
Posted on Jul 11, 2011
Fix error code 0210 stuck
error0210 is probably the O key. I found this information from Lenovo Service Site. Hope it is usefull.
You can test your key codes on this site, and as others have already discoverd and from my past experience key code 28 indicates that your error is coming from the apostrophe key. Sometimes due to normal use, keyboards may not fully release a key after it has been pressed. I would recommend getting some compressed air and try cleaning the keyboard, it is possible something is stopping it from releasing.
Since it seems that you are having mulitple errors I reccomend is to verify that your drivers are up-to-date, you can do so from the Lenovo Driver Matrix.
However, if this does not fix your error, it is possible the error has something to do with the BIOS Settings. You may boot to the BIOS and set it back to factory settings and check if the issue persists. To enter BIOS press the F1 immediately after the logo screen appears. Prior to the reset back up all of your information so that you do not lose anything as a precautionary measure.
Also, as others have stated if your device is under warranty, you may contact your local Lenovo Service Center for further assistance.
Dec 11, 2013 | Lenovo ThinkPad Computers & Internet
Error 0210 stuck key 3a
You going to need to find a new keyboard for this unit. Try ebay.com you might get lucky paying $20 or so..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 08, 2012 | Computers & Internet
I have an IBM Think Pad type 2373. whenever I turn the computer on I get an error: 0210: Stuck Key 01 It says to press F1 to fix it, I do this and nothing happens. Can you please help me fix this?
F1 may appear as a secondary key on your computer. When the error message starts, try first pushing the 'Fn' key (near Ctrl), and then clicking the F1 button. Then you can follow your computer's instructions to fix the problem.
May 02, 2011 | Computers & Internet
Machine has an error 0210 stuck key. Not sure what my daughter has done to her machine- can you help?
Machine has an error 0210 stuck key. Not sure what Problem with the Fujitsu Siemens LifeBook T3010 Tablet P
May 23, 2010 | Fujitsu Siemens LifeBook T3010 Tablet PC
Error 0210: stuck key 01
May 04, 2010 | IBM ThinkPad 390X 2626 Notebook
0210: stuck key 2B
Find a replacement keyboard for your model online, and/or have a local computer shop install it (or order and install it) for you.
Dec 28, 2009 | Fujitsu AMILO PC Laptops
Error 0210: Stuck Key 01
This is a system board POST/BIOS error code (nothing todo with Windows). The ERROR 210: is a standard POST (Power On Self Test) errormessage that indicates an error with the keyboard. The error condition is thata keyboard scan code was received from the keyboard when none was expected,after the keyboard was reset. If this occurs most of the time when you power on yoursystem, then it indicates that a key is sticking down or the key mechanical orelectrical parts are broken. Sometimes blowing out and cleaning out around thekeys will resolve this problem. Otherwise, you need to replace your keyboardwith a new (or at least a working) one.
Oct 17, 2009 | Lenovo ThinkPad R61i Laptop
ERROR CODE "0210:KEY STUCK 39
I got the 0210 stuck key error on a Lenovo Thinkpad T61, pc would not bootup, made sure keyboard was connected and cleaned with aircan and then went into bios and via F1 on startup, then went to CONFIG then to Keyboard/Mouse then I disabled the TrackPoint. Boots up fine now but the red nipple mouse is disabled due to action mentioned above. Looks like a warranty fix for Lenovo since this is a newer laptop. If it was out of warranty i would just skip using it and leave it disabled. The trackpad works fine.
Apr 27, 2009 | Compaq Presario 1200XL111 Notebook
IBM ThinkPad 390X 2626 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
