SOURCE: Caller Id
You can't send anonymous texts. There are reasons behind that. And as far as I know no one has devised a software to make it possible.
SOURCE: Nokia E71 - Saving new contact
check your phone memory limit may be it is full.
if it is still empty u need to reset all settingms of your cell phone to factory defaults.
Go to setttings then reset your celll phone.
but i think your cellular limit is over for save new contact check it .
SOURCE: blocking of caller id
I can help you with that, if you dial *67 and then the phone number, for example ( *67-715-392-0123 ) it should block your phone number from comeing up on caller id...........Hope this helps........
SOURCE: I have a Nokia e71, and everytime I call someone
Telephone settings
Select Menu > Tools > Settings > Phone.
Select from the following:
• Call — Define general call settings.
Call settings
To display your phone number to the person you are
calling, select Call > Send my caller ID > Yes. To let
the network determine whether your caller ID is sent,
select Set by network.
Last Updated: Sep 08, 2010You can block your Caller ID information (name and phone number) on a call-by-call basis. Just dial *67 before dialing the number you're calling, and your information will not show up on their Caller ID display.you can also go to http://support.sprint.com/support/article/Know_the_difference_between_restrict_and_block_on_Caller_ID/case-wh164052-20100907-101149?&INTNAV=SU:SP:HDILast Updated: Sep 08, 2010Restrict Caller ID is a restriction that is placed on your account to completely block your information (name and phone number) from being displayed on any call you make. This has to be done by contacting our Customer Care team.Block Caller ID is something you can do yourself directly on your phone by dialing *67 before the number you're calling. This only affects one call at a time, so you have to dial the code before every call you want to block your Caller ID.**************i did some research and found the answer, please provide me with FAIR feed back i.e. 3 or 4 thumbs up. according to sprints website and also htc support forum there is no way to block the caller id automatically. dont kill the messanger i just wanted to pass the info found on htc and through sprint.
