Question about Hotpoint WMA58 Front Load Washer
Have to keep switching machine off and on for lights to come on
Why does the descaling light keep coming on?
When the machine is on, the
warning light
switches off automatically, by pressing the steam
selection button for at least 5 seconds
May 03, 2014 | Saeco Magic De Luxe Espresso Machine
My scotsman ice machine have a switch board that keep showing me red light on refrigeration and won't make any Ice.
Scotsman provides a lot of service manuals for their ice machines. It will really help if you could provide a model number so I can possibly find the correct manual and information that just may help you, Thanks Sea Breeze
Apr 04, 2013 | Kitchen Appliances - Others
My indesit washing machine 12 hundred keeps flashing blue and red lights and won't do anything
Possible that the suspect could be the controller board, you can switch the machine off power for sometime, check the power outlet for the correct voltage. If not the front panel must be removed to check on the board and a possible fault of the processor or memory.
Feb 03, 2013 | Washing Machines
Hotpoint wma32pr door light keep flashing and no wash
1) test the lid switch for open
2) test the door switch for open too
3) see the diagram attached, any switch faulty can not START the motor.
God bless you
Jun 19, 2012 | Washing Machines
Selector switch keeps clicking round after 1-2
is there any flashing lights? there should b or some lights are staying on, this will b a fault code, repost the lights or pattern and i will try to find the result for you.
Apr 07, 2010 | Hotpoint BWM12 Front Load Washer
Power lights will not come on. There is power to the machine and when the switch cover is removed I can get the lights to come on but they will nopt stay on.
I extended the length of the button to the point where the switch is engaged as the problem is the switch will not keep the power on when depressed to its normal click on position. By getting the switch to an engaged power on position the machine will work. This is a temporary fix as the full fix is to replace the underlying on off switch
Dec 28, 2009 | Neff Washing Machines
Fisher & paykel - SPIN light keeps flashing and machine beeps
could be a faulty off load switch
running off balance
machine not level
depends how old the machine is then
if none of those
worn machine motor or internals
might the the circuit board
Apr 16, 2017 | Fisher Paykel EcoSmart GWL15
Brother DCP-145C. Paper jam removed. Light keeps flashing. How can I switch it off? HELP!
There will still be some scrap of paper in the machine. Get a torch and get in there. It's the only way, unless you call tech guy
Apr 28, 2009 | Office Equipment & Supplies
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Jul 06, 2008 | Ariston Technologies AW149NA Washer
Hotpoint WMA58 Front Load Washer Logo
12 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
