Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Mac installation - LaCie Design by F. A. Porsche 160 GB Hard Drive
How do I get my Huion to install on my Mac because the disc it came with will not alway it install my huion will not install on my mac
if you did not specify the base system ( apple mac) then the disc supplied will be incompatible with apple mac systems
try contacting the supplier of the program if you still cannot get it to install
Dec 20, 2016 | Computers & Internet
Tip
Reset your Apple's Original Admin Password.
Resetting the original administrator account password Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
    Choose a language, click the arrow button to continue,
  2. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note: The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
    Select your Mac OS X hard disk volume.
  3. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  4. Enter a new password.
  5. Click Save.
  6. Click the red button in the upper left corner to quit the application.
  7. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  8. Click Restart.
After following these steps, you'll want to also follow the steps in this article.
Mac OS X v10.6: Resetting the original administrator account password on a Mac that has no optical drive
These steps require a second computer that has an optical drive.
Note: If the second computer is a Mac, make sure Mac OS X v10.5.3 or later is installed. If the second computer is a PC, make sure the DVD or CD Sharing Update 1.0 for Windows is installed.
  1. Open "Remote Install Mac OS X" from the Utilities folder.
  2. Follow the onscreen instructions.
on Feb 10, 2010 | Computers & Internet
How to install wordpress on mac os
Just do a search for 'How to install wordpress on mac os'. You need to know what version of wordpress and what version of mac os.
Jul 13, 2014 | Apple Mac OS X 10.4 Tiger for Mac
Forgot password for macbook air
Dear Sir,
Welcome to Fixya Support
Resetting Your Password You can reset your administrator password and passwords for all other accounts. To reset your password, using a partner computer and Remote Install Mac OS X:
1 Follow the procedure for using Remote Install Mac OS X
To use Remote Install Mac OS X: 1. Insert the Mac OS X Install Disc 1 into the optical disc drive of the other computer. 2 .If the other computer is a Mac, open /Applications/Utilities/Remote Install Mac OS X. On Windows, choose "Remote Install Mac OS X" from the Install Assistant. 3. Read the introduction and click Continue. 4 .Choose the install disc you want to use, and click Continue. 5. Choose a network connection: AirPort, if you are using an AirPort network, or Ethernet, if the other computer is on an Ethernet network and you have an optional Apple USB Ethernet Adapter connecting your MacBook Air to the same network. Click Continue. 6 .Restart your MacBook Air and hold down the Option key as it starts up, until you see a list of available startup disks. 8. If you chose AirPort as your network in step 5, on your MacBook Air choose your AirPort network from the pop-up list. If the network is secure, you are prompted for a password. You can enter a private network name by choosing the ellipsis (...) and typing the name. 9. If you chose AirPort as your network in step 5, when you see the AirPort status icon indicating signal strength, click Continue in Remote Install Mac OS X.
10. Click Continue in Remote Install Mac OS X. 11. On your MacBook Air, choose Utilities > Reset Password from the menu bar and follow the onscreen instructions. When you finish, quit Mac OS X Installer. 12. On the other computer, click Quit to exit Remote Install Mac OS X.
I think it helps.Let Me know.
Dec 25, 2010 | Apple MacBook Air
I downloaded adobe digital editions. They ask for an id and password which I don't have. When I click on the register it sends me to this page. How do I register?
Mac OS solutions Uninstall previous versions of Digital Editions for Mac OS
You must have administrator privileges to complete these steps.
  1. From your user directory, locate /Library/Preferences/Macromedia/Flash Player/www.macromedia.com/bin/open.
  2. Drag the digitaleditions1x5 folder to the Trash, and empty the Trash.
Manually install Adobe Digital Editions for Mac OS
  1. Finish installing or uninstalling any other applications.
  2. Uninstall any earlier versions of Adobe Digital Editions.
  3. Download the installer package for your Mac OS X machine:
  1. Click Open in the File Download screen to start the installation.
    Note: If your connection times out, click Save, instead of Open, to save the installer package to your desktop.
  2. If necessary, unzip the .zip file. If you're using Safari as your browser, or if Firefox is set up to unzip files, the file unzips automatically.
  3. Double-click the .pkg file to start the installer, and follow the onscreen instructions.
Note: If your connection times out, save the installer package to your desktop. (Click the link for your Mac OS X machine, and then click Save.) Double-click the file to start the installation.
Dec 11, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Displays canot install mac os x on this computer.i would like to know why?and what can i do to install the mac os x 10.5.2
try installing Mac oS 10.5 version and then update it to 10.5.1 and 2 ,also check your installation cd/dvd
Apr 19, 2010 | Apple Powerbook G4 15" 1.5GHz SuperDrive...
My mac just wont start up. The little wheel that
maybe u not installed the system MAC Os properly or maybe your cd while installation has corrupted during installation.During this process u should not corrupting the installation.Or maybe ur computer MAC Os has a virus.I recommend u use kaspersky internet security for more protection...
Feb 23, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Driver-mac
you need to use generic driver for MAC... What kind of MAC OS are you using? MAC 10 have the drivers installed on the computer and you don't need to install the software.
Dec 09, 2008 | Brother DCP 130C All-In-One InkJet Printer
Mac OS X 10.4 Installation problem
If your computer ejects the Mac OS X 10.4 Installation DVD, it means that there's a good chance that your Mac doesn't have an Apple internal DVD drive or an Apple SuperDrive, you'll need Mac OS X 10.4 Install CDs.
If your mac is unable to read the CD or ejects it also, there's something wrong with your DVD\CD drive.
Aug 26, 2008 | Apple Mac OS X 10.4
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
10 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
