Question about Kitchen Appliances - Others
Will it slush just water? - Kitchen Appliances - Others
Frutina slush machine
if the compressor is running and it's not freezing, it may have low refrigerant. need to have a professional recharge it. if the compressor is off, check the defrost timer (if your model has one) to see if it's on defrost.
Feb 08, 2014 | Kitchen Appliances - Others
How to clean
empty the bowls, fill with cool water and flush. remove the top and the bowls. wash any residue on the bows with mild soapy water and a soft sponge. do not use a scotchbrite pad. same with the augers and the evaporator barrel. put food safe lubricant (i.e. superlube) on the shaft, the auger nose, and the spigot rings and reassemble.
Nov 10, 2013 | Kitchen Appliances - Others
I have a 2 hopper bunn ultra 2, both sides are icing over on the outside
the mix is too rich. add some water to each side. it freezes based on torque, not temp.
Aug 17, 2013 | Bunn Margarita Machine Ultra 2 Slush...
In slush machines, how come the slush does not get completely frozen?
slush is made from sugar and water bonding together. the sugar is used as an antifreeze and then the mixture is constantly spun by the machine in order for it not to freeze.
Jan 24, 2013 | Kitchen Appliances - Others
Why can't you use Pepsi or Coke in a Bunn Ultra 2 machine?
in order for the product to slush, it has to be at the right brix level (syrup to water ratio). if it's too lean, it will ice up causing damage. there are also silicon seals that will not do well with carbonation after a while.
Dec 03, 2012 | Bunn Margarita Machine Ultra 2 Slush...
When making short trips in the winter, I notice a large amount of fluid (water) on my garage floor, what can be the cause of this....doesn't seem to happen on long trips.
you may just have built up snow or slush that is melting when in your garage or you may have a leaking hose or water pump keep checking the antifreeze level and if there are no changes then its just snow and slush thats melting.
Dec 25, 2010 | Chevrolet TrailBlazer Cars & Trucks
I have an Ultra 2 bunn slush machine. One hopper
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
May 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
ICE CUBE WATER FLOW IS LOW
This is a Manitowoc model QY0214A. The water tough starts to slush up after about 3 minutes after start up cycle. The slush prevents water from flowing to the pump for circulation.
What can be wrong?
By
Greg
May 27, 2008 | Dishwashers
Kitchen Appliances - Others Logo
63 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
