Question about Avanti Refrigerators
Avanti 308ywt makes clicking sound and compressor is very hot and doesn't want to start.
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: when compressor clicks on it
sounds like a bad compressor to me, you should have 5 yr full warr on compressor, if over 5 years you can try to replace the overload relay assy attached to the side of the compressor
Posted on Nov 11, 2008
  • 308 Answers
SOURCE: Avanti wine chiller does not chill. Compressor gets very hot.
check the relay on the compressor
Posted on Jul 29, 2012
k_killigrew
  • 11 Answers
SOURCE: Whirlpool fridge gs5shaxnq00 start relay clicking and compressor not coming on. I replaced thr start relay and the new one still clicks and the compressor still doesn't come on
sorry but compressor is gone,new compressor needed
Posted on Aug 28, 2012
SOURCE: Haier model HRQ04WNAWW refrigerator.
yes but the fridge doesn't turn on
Posted on Jun 01, 2013
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Nataly if there is not any cold air anywhere and compressor is running that indicates a Freon leak and worth very little due to repair cost. You must be sure that compressor is running not the fan noise
Appliance 911 Sea Breeze
Nov 12, 2015 | Avanti Refrigerators
Freezer gets cold bottom fridge wont
Food compartment fan may have failed or freezer chocked with ice blocking air flow to fc.
Nov 23, 2013 | Avanti 308YWT Compact Refrigerator
The compresor make a noice but not start
Faulty compressor. May be new electrics would work but most likely compressor needs replacing
May 15, 2012 | Avanti Refrigerators
My Avanit WC54 wine cooler turns on, however it does not cool. Every few minutes it makes a clicking sound
if you are handy go to a refrigeration supply hoese and buy a 3-1 pack remove the wires from the compressor let it cool if hot and hook to 120 volts wiring it shows you on the package..........luck
Jun 16, 2011 | Avanti WC54 Wine Cooler
I have a compact avanti regrigerator. It doesnt get cold anymore. What do you think might be the problem? I bought it since 2007.
There are three possible reasons for this;
\the thermostat needs replacing
\The refrigerant has leaked out
\ the compressor has failed
Either way you will need a technician to look at this as it involves an electrical diagnosis
Apr 05, 2011 | Avanti 308YWT Compact Refrigerator
I have an Avanti Upright Freezer, Model #310VFYWH. It quit working recently. I've unplugged the unit and waited 15 minutes, then plugged it back in. Still won't work. Today I pulled it out from the wall...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 13, 2010 | Avanti Kitchen Ranges
For the temperature, to make it colder to we turn the knob towards the higher numbers or lower?
Normally the lower number is more cooling and hence the setting is ideal to be kept at mid point.
In twin door adjustment witth single control lower setting more cooling to freezer and as it goes up the temp of the fridge increases.
So you might need to recheck with this model
Sep 16, 2010 | Avanti 308YWT Compact Refrigerator
It just do not get cold, sounds like it is working, could be temperature control?
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 21, 2010 | Avanti 308YWT Compact Refrigerator
Refrigerators Logo
26 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
