Question about Compaq R1500 ( 295459-001 ) UPS System
Emerge ups 500 long beep when power on without connecting any thing to ups
My pc restarts when there is a power failure,even if the ups is functioning..
Then you don't have the computer's power plug connected in the correct side of the UPS or the UPS in not working correctly and needs to be returned.
Jun 29, 2012 | Computers & Internet
My pc restarts when electricity is gone,even if ups is connected
Hello, I think that there is not enough or spare Volts left, try connecting your pc to another electricity spot.
Hi, I've APC UPS ES 500 connected to my desktop computer. Have 1 year old battery but when checked without load displaying 12 V. Issues are: a. ups doesn't supply...
A battery showing 12V without a load attached means nothing. You probably have one or more weak cells and they simply cannot supply enough power. I would try a new battery before I try anything else.
Jul 21, 2011 | Office Equipment & Supplies
I built my own pc, it ran great for about 6 months, now when i turn it on the tower beeps 3 times and the monitor says no signal, ive checked all the connections, took the video card out, and cleaned it...
3 beeps is a good indication that video card is dead. Try the card in another slot if possible, or another PC. If it does not work, it is time for a new one. At 6 months old, you may have luck with a warranty. Contact the manufacturer. In the meanwhile, hit up the local PC repair shops for a cheap used card so you can at least limp around the internet while you solve you broken card problems.
Jan 01, 2010 | PC Chips P25G Motherboard
My 485VA back up system beeps after I have a few things plugged into it. Does the beeping mean the battery is bad?
Try only the computer and monitor - it may be overloaded, 485VA is around 400W only, so it won't accomodate much more than a standard computer + monitor.
Especially a laser printer is very power consuming and should not be connected to any UPS.
Nov 28, 2009 | CyberPower 485VA UPS Backup (BE485) UPS...
Seagate 500gb Agentfree Making a beep every 15 seconds
It sounds like your hard drive is damaged my friend. Hard drives are very, very dilicate pieces of machinary. The disk is paper thin and any sudden jarring, especiaiy dropping it creates a warp in the drive. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Jul 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computer won`t start up.
Unplug all the cable from the Computer,
Press and Hold the Power button for 30Sec. without connecting any cable,
Connect the Power cable and Monitor cable then turn it back on,
see if your computer turn on or if you get any thing on Monitor,
if you hear any beep sound or any thing after doing all this
let me know i will be more that happy to help u.
Thanks
Nov 17, 2008 | Computers & Internet
It wornt start up
Mandy can you be a little more precise what won't start up? your on the Internet, something started up.
Nov 01, 2008 | Computers & Internet
APC UPS CS 500 (BK500EI)
If you can repair pcb then check overload protection section.There is some shortinng in components or ic could be demage.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 07, 2008 | APC (BK500TW) UPS System
Compaq R1500 ( 295459-001 ) UPS System Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
