Question about Bunn Coffee Makers & Espresso Machines
Heating element heats up slow on bunn coffee maker
It used to heat up fast, now it takes hours
  • 131 Answers
SOURCE: the water is not heated when I put my Bunn coffee maker on
If you plugged it in before water started coming out of the sprayhead (about 2 pots full of water poured in) you might have burnt out your element, But lets start with a simpler answer. Did you check the main burner switch on the side of the tank?
If so, then I would suspect your main heating element
Posted on Feb 12, 2009
  • 131 Answers
SOURCE: bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
Posted on Feb 13, 2009
ginko
  • 19396 Answers
SOURCE: WEAK COFFEE & NOT HOT ENOUGH
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on Apr 01, 2009
EsWorld
  • 1618 Answers
SOURCE: My Bunn Pour-Omatic coffee maker (White) Heat up
Most likely suspect is the thermostat, however you might want to check the limit switch also(located on boiler between elements).
Posted on Jun 20, 2009
SOURCE: water wont come out of my bunn coffee maker
The first pot of water you put in the coffee maker just fills the water tank which is then heated up , once it gets to temperature you then pour second pot of water this pushes the hot water out of the tank through the coffee grounds into the waiting pot. This way you can make coffee faster than a regular coffee maker.
Posted on Jul 19, 2009
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
Bunn b10-b neads new heating element assembly and can't find one on internet. will not keep reservoir heated.
Unfornately, the heating element is not repairable. If you will call 800-352-2866 with your model and date code, we will be able to further assist you.
Aug 07, 2010 | Bunn BT10B Coffee Maker
Our Bunn VPR coffeemaker takes a LONG time to heat up the water. If we don't wait several hours between pots of coffee, the coffee is luke-warm at best. Does this sound like a heating element or...
We left vinegar in the coffeemaker overnight. Seems to have done the trick - water is heating up now after 20 or so minutes instead of several hours.
Jan 05, 2010 | Bunn VPR Coffee Maker
The Maker isnt brewing very fast it takes 20 to 30 Min to get a pott
Hi Edi,
Two things come to mind, either the tubes that allow the heated water are partially blocked or the heating element is on it's last legs.
If it seems to be heating up, run some vinegar though it. This dissolves the deposits left by boiling hard water. Then run the cycle a few times with fresh water to rinse it.
If it doesn't seem to be heating, I'd first check the warranty. If it has expired, Replacement is likely the remaining option.
Best Regards
Mike
Please excuse the nandini post, he's new.
Sep 06, 2009 | Bunn NHB Coffee Maker
Jun 18, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Adjusting the temperature
Our Bunn VPR was delivering luke warm coffee. The problem was lime scale buildup on the heating element. I recommend using a cleaner such as Brew Rite or a vinegar solution. If it still does not heat properly, unplug and remove the heating element for cleaning. This corrected our problem.
Jun 17, 2009 | Bunn VPR Coffee Maker
Bunn commercial coffee maker plug overheats, no hot water
Feb 13, 2009 | Bunn Coffee Makers & Espresso Machines
The water is not heated when I put my Bunn coffee maker on
Dec 25, 2008 | Bunn NHB Coffee Maker
Bunn coffee maker trips the breaker
It is possible that you have a short in your limit thermostat, but most likely this is caused by small holes in your main heating element. these units start to split length ways down the element, causing a short to ground through the water. These elements are readily available at your local Bunn repair shop.
Oct 27, 2007 | Bunn RL Coffee Maker
Coffee Makers & Espresso Machines Logo
13 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
