Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint drum wobbling
Drum wobbling after fitting bearing kit
ngfam1
  • 639 Answers
SOURCE: Hotpoint WMA32 drum problem
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
This machine in three years ago in the UK cost 280 pounds
You probably can buy it today for half the money from then!
I suggest a new one and not that model which had a lot of problems! Speed Queen has the best warranty.And does 8 loads a week for 25 years.
They start at about $549 in the States!
Not sure if they sell it in the UK????
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
  • 100 Answers
SOURCE: hotpoint wf541p bearing
ebay sell all kinds of bearing kits. about £10 usually.
Posted on Jan 28, 2009
  • 153 Answers
SOURCE: Replace drum bearings on hotpoint aquarius wf000g
You really don't want to know how but here it is. The bearing is located in the rear shell and is not removable the rear shell has to be replaced which means removing the tub assembly from the machine and completely disassembling. With 30 years of appliance repair the last one I did took about 3 hours.
Posted on Feb 26, 2010
oldmanewtoys
  • 414 Answers
SOURCE: My hotpoint tumble dryer drum is not turning.It is
there is a belt that runs around the drum,it is either worn or broken. Pressure from belt keeps the drum tight
Posted on Mar 08, 2010
Testimonial: "Thank you I will take the back off and have a look. Are the belts easy to replace ?"
apart4u
  • 213 Answers
SOURCE: Access to drum on a hotpoint WMM39A
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Posted on May 26, 2010
Hotpoint WM56 front loading. Machine makes a deaf inducing noise when spinning in particular.The drum will wobble front to back when pushed by hand and does not seem to sit level with the outer drum, it is...
Ours did exactly the same. The drum bearing's worn and the spider had broken causing a noise like a road drill. Check out the video on Youtube from Apart4U. It's a pig of a job though.
Apr 12, 2011 | Hotpoint WM56 Front Load Washer
My partner's Hotpoint WT960 makes very loud grinding sound when spinning. I suspect the drum bearings are gazacked. Do I need to change the drum support and bearings & seal or just the bearings? Is it...
Hi Joe.
A lot depends on construction of drum.
Remove the top cover and look at the plastic outer container, if it is a one piece consonstruction, then unfortunately you cannot fit new bearings, as it it comes supplied as a complete unit.
However, if you can see the 2 drum halves held together with screws, then you can fit new bearings.
You will not know if the spider or drum shaft needs to be replaced until the it is stipped down, a fifty- fifty chance
It is an involved repair as it entails removing the whole container from the cabinet, and do not fit any other bearings than the genuine ones.
It comes as a bearing and seal kit from Hotpoint.
WWW.HOTPOINTSERVICE.CO.UK
Good luck
Dec 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have got a Hotpoint Aquarius tumble dryer. I have just put a new belt on it and a new rear drum axle with new bearings and front bearing pads.I have made sure that the front of the drum is sitting...
Make sure that you have fitted the spacing washer provided with the bearing kit on the drum shaft, and that it is sitting between the rear of the drum and the rear bearing, double check that you have got the front of the drum sitting on all the plastic bearings at the front.
If it still catches, then fit another washer on the drum shaft to space it off from the rear of the cabinet.
Mar 25, 2010 | Hotpoint Dryers
Tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Jan 31, 2010 | Hotpoint Dryers
Hotpoint WMA35 - Noisy on spinning
This could be the bearings.
If it is you have two options:
1 - Buy another washing machine
2 - DIY possible for about £30 with all the RIGHT TOOLS, £100 if doing it properly. And even with the right tools this will take you about 3 hours, probably more.
To replace the bearings you NEED to have:
1) The parts - The replacement bearing kit (£30) and hotpoint recommend a new spider (£65) as well.
2) A tool to push the drum shaft from the casing.
3) A tool to remove the beaings. It is possible to buy a new rear casing with the bearings already fitted for about £70.
4) Patience and a supply of tea!
Method
1 - disconnect everything and I mean everything see number 2.
2 - remove the drum casing from the chasis
3 - take off the pulley wheel
4 - open the casing
5 - remove the drum from the casing. DO NOT USE A HAMMER as the shaft deforms very easily (good job I've a new "spider"!)
6 - fit new "spider" if using. Here is where you find the bolts are rusted completely solid from spider to drum and require drilling out.
7 - remove bearings from casing (hence the need for the bearing removal tool)
8 - fit new bearings and rebuild machine (hence the need for the bearing fitting tool)
However I stopped at number 7 due to not having the right tools and I have no idea how much the right tools cost.
Trust me, take option one! £100 is a third of a new machine!
Mar 17, 2009 | Hotpoint WMA35 Front Load Washer
I have a hotpoint first edition 800 wm 51 can you tell me is it east to change the bearing in the drum
It is a fairly straight forward repair to do, if you know what you are doing.
The bearing comes as a bearing kit, consisting of 2 bearings and a shaft seal, yuo will also need a new container front seal, and depending on how badly the bearings are worn, you may need to fit a new drum shaft as well.
Again depending on how badly the bearings are worn, they can cause wear in the bearing housing, this being the case, then you would have to fit a new outer tub.assy complete,
This then puts it beyond economical repair.
Obviously , you will not know what is req'd until it is stripped down.
Plz rate my comments towards providing a solution to your problem.
Thankyou.
Jan 25, 2009 | Washing Machines
Hotpoint bearing lubricant?
No lubricant is req'd..The rear drum bearing is already impregnated with lubricant.
Dec 13, 2008 | Hotpoint NWXR473EV Dryer
Hotpointfront loader
It is very likely that the bearings have failed. I have had a hotpoint wma33 fail at 23 months and had hotpoint fix it...
This is not an easy task to undertake on your own I spent a while looking into this.
If you have warranty (machine is less than 1 year old) or paid for extended cover then call hotpoint to replace... (They will do the whole drum its quicker). This should be free.
If you don't have warranty (your machine is older than 1 year) then still call Hotpoint - you will be charged £90 callout but parts are free for machines less than 5 years old. This is what I recommend.
or - do it yourself ( NOT RECOMMENDED)
I know two people who have purchased the bearings and spider kits - and wasted about 3 days because these things are really awkward to remove and refit. They both swear that £90 is a bargin after buying the spider and bearing see:
http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=954798&brand=&model=wma33&part=spider
This spider costs 61.25 + delivery - ouch.
As hotpoint will fit half a drum or full drum (Depending on what is on the van for £90) the actual cost of a half drum is 75.99 + delivery see: http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=639770&brand=&model=wma33&part=drum
and a full drum costs 176.96 + delivery
see: http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=639763&brand=&model=wma33&part=drum
They take away all the rubbish at the end also!
I hope this helps
Please dont forget to rate me as a fixya.
Mar 20, 2008 | Hotpoint WMA35 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
16 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
