Question about Matsonic MS9158E+ Motherboard
Driver vga graphics - Matsonic MS9158E+ Motherboard
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they want...
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
Mar 26, 2015 | Lenovo ThinkCentre Computers & Internet
Problem install X300 Xtenda Multi Box. Windows XP code 10 for X300 Graphic Controller.
look up the driver for it. you normally need to download drivers for things before you install them
Jun 19, 2010 | NComputing X300 3 User Expansion Kit...
Problem with Standard VGA Graphics Adapter
You need to install the drivers for the graphics card that you have. Search for the drivers on toshibas website.
Jun 24, 2009 | Toshiba VGA Board Graphic Card
Vga card driver
It has a ATI Mobility Radeon 7500 graphics chips and u can dl the drivers from: http://ati.amd.com/support/driver.html
Oct 14, 2008 | Dell (1R493) (32 MB) Graphic Card
Download vga driver
you can go to nvidia.com and get the driver you need.
Jul 25, 2008 | Nvidia Apple Geforce4MX (64 MB) Graphic...
Tell me the product i am using in my pc . in Device manage it was saying that i don't have vga drivers
the vga drivers are the generic driver that windows needs to use the graphics, these are normally found on the motherboard driver cd as the vga is normally an onboard graphics driver, but which one only you will know?
Oct 15, 2007 | Computers & Internet
Matsonic MS9158E+ Motherboard Logo
37 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Alan Hohenbrink
Alan Hohenbrink
Robert Karst
Robert Karst
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
