Question about Toto Home
Toto auto sensor toilet leaks when flushed - Toto Home
arealplumber
  • 33 Answers
SOURCE: Toto GMax Flushing System drips
What you are experiencing is a flapper valve problem. Since I don't know what model you have I will give you a link to the generic GMax unit. Here is the parts breakdown for a GMax
Toto GMax
I would suspect you need part #7 on this diagram a flapper valve. Take the old one with you since different colors ones are used on different models. You should go to the Toto site to locate a dealer first. You can find their site here:
Toto USA
Hope this helps and please remember to rate this!
Posted on Dec 09, 2008
  • 14 Answers
SOURCE: Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Posted on Jan 10, 2009
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
smokenic
  • 49 Answers
SOURCE: New Toto toilet continues to trick water
check the water level in your tank if it is filling ,ajust the float in your tank so it stops before going over the overflow. if not your flapper is the culpret
Posted on Sep 20, 2009
SOURCE: toto toilet with gmax flushing system blue top
I have the same problem and can not find a solution. The toilet flushes fine but then a delay in filling up the tank occurs. Is there a part I can replace? Does something need to be cleaned or cleared?
Posted on Jan 15, 2010
Invisi Series ll Round Dual Flush Plate & Buttons
That would be a leaking flapper valve. They are inexpensive and easy to install. Good luck
Jun 09, 2014 | Toto Aquia II Dual Flush Toilet
I have a toto duel Max toilet and the water leaks out of the bowl slowly. By the end of the day, I will have no water. Please help
Check flushing mechanism at the bottom of tank to check if it vopens and closes securely. and nothing blocks it.
Jul 27, 2013 | Toto Aquia II Dual Flush Toilet
Flush Valve leaking
replace the whole valve. It's cheap and easy to do. Probably you can install a universal valve. Look on e-bay or amozon
Dec 05, 2012 | Toto Aquia II Dual Flush Toilet
A small leak under the toilette, the seal has been changed many times and the toilette has even been replaced. Plumber says deffective toilettes? The leak seems to only happen when or after it is...
I've installed a lot of Toto toilets and have had few leaks but, not from the one piece toilets. It might be a problem toilet but, I would be sure the drain is not blocked causing a small back up after the flush.I have seen this happen many times. The toilet can be pulled and a 5gallon bucket of water can be poured down the drain to test this before replacing the toilet. also be sure water is not spraying on the top of the tank lid and leaking down the back of the toilet.If you flush the toilet with the lid off it should be easy to see if that the problem. hope this helps.
Dec 21, 2010 | Toto ULTIMATE ROUND FRONT ONE PIECE TOILET...
REMOVAL OF TOTO AQUIA TOILET
first shut off water and then flush the john. this will remove most of the water. for water remaining in tank us a sponge or similar to remove remaining water. find where toilet bolts to floor and remove these bolts or nuts. then pick whole toilet from floor, there should be a wax ring under toilet, replace wax ring when putting back in. when putting back in just push down on toilet to squish wax ring and bolt to floor, turn on water and check for leaks. good luck
Apr 16, 2010 | Toto Aquia II Dual Flush Toilet
G-max flushing system is not filling to proper level
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
My toto toilet has both 1.6 gal and 6 gal flushes. the short flush doesn't go down.
I am not a toto expert but i think i understand the gravity control toilet concept.A gravity flush tank type toilet flushes do to the force of water traveling from the tank to the bowl in a small passageway and forces the water in the bowl towards the integral trap in the toilet.In other words the water isnt dumping quick enough or the passageway is restricted.,My guess is the flush valve isnt dumping all at once.
Dec 01, 2009 | Toto Aquia II Dual Flush Toilet
Flush problem with toto toilet
If your hooked to city water it can be cause of the high water pressure comes across and keeps flapper from seating rite. Take a empty plastic bottle,cut it in half long ways. flush toilet then place plastic bottle between fill valve and flapper,trying to devert water away from where flapper seats. good luck.
Jul 23, 2009 | Toto Dartmouth 2pc. E/F Toilet ...
Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Mar 07, 2009 | Toto Aquia II Dual Flush Toilet
Home Logo
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
