Question about Hotpoint Ovens
Homeking oven hof605ss
Oven won't start - stuck in auto mode
2 Suggested Answers
  • 5 Answers
SOURCE: homeking zeros are flashing and oven not working
the power in your house unplug your oven then plug back in.
Posted on Oct 16, 2012
Multi purpose oven won't work after power cut have reset clock, light won't work. Is making all the right sounds just won work
power supply from clock damaged not by power cut but voltage spike when power resumed the oven thinks its in auto mode permanentley thats why it wont come on ,new clock or power board needed.
Feb 03, 2017 | Neff Ovens
Try turning off the circuit for a minute, then set timer again.
Often a little picture/icon of a "baking tray with heat" when timer is passing power on to the thermostat.
Also, those timers fail often enough, is the oven brand new (or recent blackout)?
Oct 17, 2013 | Ovens
Homeking zeros are flashing and oven not working
Oct 16, 2012 | Kenmore Ovens
Westinghouse oven pof668 in auto mode - how do I get it out of auto mode (am renting this property). Oven and grill are not working as power was off until recently
Most models won't work when on Auto. Generally there are push buttons under the clock and one has a picture of a hand (Like a cop holding up his hand to say "Stop"). Press this button and it should go back to manual mode and allow you to use the oven.
What I have said so far is pretty much a guess, based upon experience. I'm also guessing that you don't have a manual to refer to either. However, w
hile I can't find the specific manual for your model, there is a westinghouse oven manual here:
http://manuals.appliancesonline.com.au/westinghouse-dualfuel-ovens/westinghouse_duelfuel_ovens_manual.pdf
and I would bet that the clock setting instructions on page 18 are exactly the same for your appliance!
Jul 28, 2011 | Ovens
I bought a house with a Defy Gemini Petite Chef oven but it is not working. The oven flicker on Auto. How can I delete the Auto?
Most models won't work when on Auto. There are push buttons under the clock and one has a picture of a hand (Like a cop holding up his hand to say "Stop"). From left to right numbering the buttons 1-6, this is button 4 on your appliance. Press this button and it should go back to manual mode and allow you to use the oven.
You can download a manual for this appliance from here:
http://www.google.co.uk/url?sa=t&source=web&cd=1&ved=0CBoQFjAA&url=http%3A%2F%2Fwww.defy.co.za%2FgetFile.asp%3FPath%3DD%3A%255Cinetpub%255Cwwwroot%255Cwww.defy.co.za%255Cimages%255CManuals%255C061_896_Gemini_Petit_Chef.pdf%26File%3D061_896_Gemini_Petit_Chef.pdf%26Size%3D342953%26Name%3D061_896_Gemini_Petit_Chef.pdf&rct=j&q=Gemini%20Petite%20Chef%20manual&ei=WfAWTqmnOsmYhQeotZHMBQ&usg=AFQjCNFC3Mdb5clrC_aHL8sq4P0zkfhmZA
Or google " Gemini Petite Chef manual " and the first hit has the link
Jul 08, 2011 | Ovens
The cooker has set on auto so the oven wont work
Need the make and model.
This is obviously a blind guess, so if I'm wrong, please come back and tell me the make and model so I can investigate further for you. If I'm right then feel free to tell me what a great guy I am :-)
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
Electrolux EOB 966 stuck in auto mode
Hi, try to switch it off at the main switch. Wait for 10 seconds, then switch the power back on, reset the clock, and you should be fine.
Cheers
Feb 12, 2009 | Electrolux EOB6696X Electric Single Oven
Unable to get cooker out of automatic mode
If your oven has timer and it is flashing AUTO then you need to reset it to manual for it to work.
If no timer then it could be a faulty door micro switch, located at the front left side..\Hope this helps, please leave feed back.
Thanks
Nov 25, 2008 | Hotpoint Ovens
Ovens Logo
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
