Question about Dell Inspiron 530 Desktop Computer
How to turn off sleep mode in Windows Vista
Can not run disk defragmenation because computer goes into sleep mode after 20-30 minutes
  • 70 Answers
Goto control panel then power option now change plan setting front of balanced.now you see the option put the computer on sleep,select never.
Posted on Apr 05, 2015
    Top Expert:
  • Dell Master
  • 4,740 Answers
Try going into your control panel and look for your display icon,see if you can do it from there.
SOURCE: Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
Posted on Mar 25, 2008
  • 285 Answers
SOURCE: Monitor goes into Sleep Mode immediatly upon turning on computer
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
Posted on May 24, 2009
rcirone203
  • 70 Answers
SOURCE: Computer goes to sleep before it even starts up
Hi there, it appears as though the Power Options are set too short a time and the PC is going into sleep mode. Go to Start menu/Control Panel and look for Power options. Set them all to "never" This will prevent her PC from going into sleep mode. Good Luck.
Posted on Oct 26, 2009
  • 20 Answers
SOURCE: sleep mode problem
hey , first go to same mode in ur PC by pressing F7 .
thenblue window will appear so there select normal mode . thus ur PC will never go to sleep mode.
Posted on Jan 22, 2010
nonontech
  • 4737 Answers
SOURCE: I have a Dell Inspiron 546 running Windows Vista.
Well as per your recent comments, it seemed you've already tried removing the CMOS battery. There are many possible causes, like the Video card, the Ram, the Bios, the Reset switch, the front panel connector or even the hard disk drive or the CD/DVD drive or Power Supply unit.
First, you need to disconnect or uninstall everything from the motherboard except the Processor with HeatSink Fan and the Power Connector(s). Unplug the Front Panel connectors (the connectors which come out from the front part of the cabinet, connected to the motherboard). You need to be careful with the main Panel, i.e. the power switch, reset switch, hddled, power led. Before you unplug them, note down the connection sequence if you might forget it. Also take note of the power switch pins, you'll need to short it after a while. Unplug the HDD data and power cables, Cd/Dvd Drive's cables, and everything else. Remove the ram, remove the bios battery.
(don't remove/disconnect the system speaker)
Now, connect the power cord and the monitor on the back, power on the monitor (I would recommend you to connect the monitor via VGA), take a screw driver and short the power switch pin on the motherboard (I've mentioned this to you to take note). Look at the cpu fan and on the monitor, at least the system speaker should beep this time with the beep codes indicating that there's no Ram/Memory installed. (If nothing happens, then there's problem with the motherboard, could be the video card or could be the bios or something else) If so, then turn off and install one Ram. Again power up and check the status, if there's nothing wrong with the Ram, Motherboard, Bios or video Card, then you must see the Bios' System info screen (black screen with white texts after the Dell Logo flashes). If it doesn't seem anything happen, then try with the other/another ram. (If it fails, then there's problem on the motherboard, you better get another than repairing it.)
If it boots up with the Bios System info screen, then turn off and connect the front panel and other panels, like usb or audio etc.. Again power On the machine from the Power switch (this time On/Off switch), verify what happens. if it's ok, turn off and reconnect the hdd and the dvd drive and so on.... untill everything is reconnected and reinstalled or you'll stuck somewhere during the steps when the faulty component is installed.
Let me know the outcome, sorry, this is too long.....but I don't want you to get confused.
Posted on Nov 08, 2010
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Sleep mode won't wake up
dont let computer go to sleep mode, just turn of screen, run disk cleaner
Apr 23, 2012 | Acer Computers & Internet
When the CPU switch on, the system running upto 10 minutes. after that the monitor screen automatically off.
Here is artical I found on how to disable sleep mode on a monitor, this would be for VISTA or 7, if you are using XP it's a bit different. ____________________________________________________________ How to Disable Sleep Mode on a Monitor
Your computer monitor or laptop screen will enter sleep mode after your computer remains idle for a set period of time. You can disable sleep mode if you prefer the screen to remain illuminated. You merely need to change a setting in the Windows Power Management properties box.
Difficulty: Moderately Easy Instructions
  1. Click "Start" and "Control Panel".
  2. Click "System and Security" and "Power Options". This will bring up a new dialog box.
  3. Click the menus to the right of "Turn off the Display" and set them both to "Never". This will disable sleep mode.
Read more: How to Disable Sleep Mode on a Monitor ' eHow.com http://www.ehow.com/how_6953659_disable-sleep-mode-monitor.html#ixzz1CiGFFyLk
Feb 01, 2011 | Acer AL1916W 19" LCD Monitor
Goes into sleep mode will not come back on for 2 weeks or longer
It might be setup to go into sleep mode if it is left idle for a certain period of time. To change the settings click the following(I am assuming you have windows vista or windows 7):
Start,Control Panel,Power options,Choose when the computer goes to sleep(look on the left side),Then adjust the settings to what you wish by clicking the black arrow there.
Also check the "choose when to turn off the screen" in the same spot you clicked Choose when the computer goes to sleep.
Nov 10, 2010 | Dell Inspiron 1525 Notebook
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Dell Inspiron 530 Desktop Computer   Logo
74 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
